12-25-2009, 12:10 AM | #1 |
Rock Stacker Join Date: Dec 2009 Location: deroche b,c canada
| losi 1/10 comp shafts rub on lower link
hi out there i'm a newbe to all the crawler seen, i bought the lcc it is stock suspension and my problem is when flexing it out the lower link comes up and hits the drive shaft.i under stand limit the travel would work but is there any ideas out there so i can keep full travel thanks dennis frm bc |
12-25-2009, 12:45 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
what do you define as full travel? if three tires are touching the ground how high can you lift one tire on the axle with the rubbing link/shaft
12-25-2009, 01:16 AM | #3 |
don't laugh but a case of beer lol.if i hold the truck by hand and twist the suspension just before the shock bottoms out,the lower link meets up to the shaft and then will push on shaft slightly.this happens on both ends just opposite angles. thanks dennis frm bc merry ho ho |
12-25-2009, 02:12 AM | #4 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
This common on all LCCs. It has been said that you need to limit your shocks with about 3/8" fuel line to keep this from happening. Kind of a bumber. The only fix for this that I have seen, is using the drive shafts from the Night Crawler. It has dog bones for drive shafts and this way it has enough room for the links not to hit at full flex. Hope this helps. It is only thing that I have heard of. |
12-25-2009, 07:22 AM | #5 |
Grab some of these, they work great. If you lay your shocks down you might get a little bit of rub, but almost none. Axial Racing Shock Damper 3X7X8mm (10pcs) #AXA1358 http://www.tcscrawlers.com/Axial-Rac...8-p-17041.html |
12-25-2009, 02:23 PM | #6 |
Rock Stacker Join Date: Sep 2008 Location: Folsom
I have a lcc that i compete with and i did limit the down travel on the frount and the up travel in the rear. I use pen springs they last longer then fuel tube . my shafts do hit the links and have never had a problem with it. so just set it up how it works for you and go have fun. |
12-25-2009, 05:22 PM | #7 |
thanks a bunch i do like the pen spring idea,i'll work on setting it up better as i run more packs through it and get to know what works for me dennis frm bc |
