12-26-2009, 08:15 PM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: Dyersburg
| Ckrc bta
I have this set up on my new crawler. also have alum c on it. i can knot keep the screws tight on the knuckles . i have put loc tight on them . any help out there. thanks Kenneth |
12-27-2009, 08:43 AM | #2 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
| clean everything really good with denatured alcohol, then make sure you put only a small drop of blue loc-tite on eack screw. using too much causes it not to dry properly. hope this helps.
12-27-2009, 09:00 AM | #3 |
RC Axle Master Join Date: Mar 2008 Location: Las Vegas
If your running the CKRC knuckles then the brass bushing are sitting below the knuckle and the screw is riding on it. I took a file and filed down the top of the knuckle until the end of the bushing is higher then the top of the knuckle. Put the screws in with locktight and you should be good to go. You will need to do this on both sides of the knuckle where the screws go in.
12-27-2009, 12:41 PM | #4 |
thanks will look at that
