12-30-2009, 10:30 PM | #1 |
Newbie Join Date: Dec 2009 Location: Ft Myers
| Custom Crawler acting up
I recently purchased a lot of RC cars from a gentleman, included was an Axial SCX10 (Love it) and a custom crawler. The Axial is running just fine, the custom crawler is acting up though. Whenever I go to throttle up the truck is fine, then it starts to almost stutter as if the motor were struggling to keep the gears moving. When lifted off the ground the driveline works flawlessly, when set down the truck is incredibly jumpy. I dont know much at all about the truck or the axles on the truck, I do know that the trans "appears" to be an RC4WD trans. I have taken it apart and went through it and everything seems to be fine in it. The speed controller is fine as I have tested others that I know work in place of it. Any help would be deeply appreciated, Happy Crawling! Luke |
12-30-2009, 10:42 PM | #2 |
Pebble Pounder Join Date: Dec 2009 Location: virginia beach
does it have a brushed or brushless motor??
12-30-2009, 10:44 PM | #3 |
pics could help
12-30-2009, 11:01 PM | #4 |
It is a brushed Integy 55x1 motor, as for pics let me fire up my old bucket, pics coming soon. Thanks, Luke |
12-30-2009, 11:48 PM | #5 |
12-31-2009, 11:57 AM | #6 |
That truck appears to be, as you mentioned, a custom crawler with an RC4WD R2 Tranny, Tamiya Hi-lift axles and what looks like an Integy Lathe motor. It sounds like you need to replace the brushes and springs in your motor. Here is some info on RC motors: http://www.rccartips.com/rc-electric...ning-guide.htm http://www.rcracingusa.net/electricmotor.htm http://www.beatyourtruck.com/forum/s...ad.php?t=57986 |
12-31-2009, 12:11 PM | #7 |
Thanks aton Jeremy. This leads me to another question, rather than rebuilding the old motor, what motor do you suggest i use? Would a stock 27T motor suffice, or is that too much power? Thanks, Luke |
12-31-2009, 12:21 PM | #8 |
Well, I'm not exactly sure what motor you are currently using, but I'd wager that it is probably a 55T, so you'll see a drastic increase in speed! If you are just using this truck as a backyard basher/ trail truck (judging by all of the waterproof components, it looks like this is what the previous owner used this truck for), then that 27T motor would probably work nicely. I like 35T motors in my scalers and that 27T isnt far off. You'll have a lot less torque with a 27T than with a 55T, but it should be fine. Install the 27T and give it a shot! You dont have anything to lose but a bit of your time...
12-31-2009, 12:55 PM | #9 |
Well I dont own any motors aside from 19turn, so I would be purchasing one, Id like something from my LHS but if you think a 35 turn would be better I may order one, would it be worth waiting a week for 1 I guess is my question?
12-31-2009, 12:58 PM | #10 |
Well, that depends on how impatient you are. I am terribly impatient and usually want stuff quickly. A good 35T handwound motor will provide great speed and torque for your truck...
12-31-2009, 01:21 PM | #11 |
i would have to say im pretty impatient haha. Who makes a good 35T, Ill probably order one for a spare. Thanks |
12-31-2009, 01:26 PM | #12 |
I run the Fantom Racing Blitz 35T motors in my comp truck (Bully) and have nothing but good things to say about them.
12-31-2009, 06:27 PM | #13 |
I had an extra integy 55turn laying around and it is working much better now. Thanks all, now to do some chassis modification |
12-31-2009, 06:36 PM | #14 |
Glad you got it figured out! These electromagnetic motors dont require a lot of maintenance, but occasionally you have to replace the brushes and springs.
12-31-2009, 07:03 PM | #15 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
it sounds like the comm is glazed too,,it isnt real hard to do internal motor maintanance,,take the screws out of the end bell and carefully pull the armature out,,just release the brush springs first and pull the brushes clear,,,the armature will stck a bit as it is pulled to one magnet or the other. put the amature in a high speed drill or a dremel and turn it at medium speed,,,use very fine sandpaper or a fingernail polishing stick to turn the comm,,thats the copper colored ring at the end of the armature opposite of the output shaft,,once its all shiny then reinstall with new brushes and springs,,make sure you apply very slight pressure to the comm when you polish it though,,you dont want to groove it |
12-31-2009, 07:42 PM | #16 |
Rock Crawler Join Date: Jun 2008 Location: Naples
If the comm is not too badly grooved then you can remove and clean the brushes, cut a pencil eraser to same size as the brush and push it against the comm through the brush port and give the armature a few spins, that will clean up the comm, done this a few times, and it works pretty well.
