01-04-2010, 07:41 PM | #1 |
Newbie Join Date: Jan 2010 Location: MASSILLON
| I need suggestions and info
Hey, new to the sport, got a ax10. Need any advice i can get
01-04-2010, 07:42 PM | #2 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
what do you wanna know?
01-04-2010, 07:43 PM | #3 |
Take it apart put it back together, Drive it, make some adjustments by looking at other people's rigs or your own. Then buy or make the parts you want to upgrade.
01-04-2010, 07:49 PM | #4 |
Newbie Join Date: Jul 2009 Location: Southern Ontario
| and read read read....there's an unbelievable amount of info here...just gotta sit down and sift through it all :P
01-04-2010, 07:51 PM | #5 | |
I forgot about reading and searching. I spend 3/4 of my time on this board searching and reading. Not to be an ass but it's true. Tons of great information on this site. | |
01-04-2010, 07:53 PM | #6 |
I bought it used on ebay, heres wht it has
01-04-2010, 07:54 PM | #7 |
polished axial bent links *polished axial bead lock rings *4 wheel steering *derlin center skid plate that moves arms to the inside of the chassis *rc4wd servo mounts with 4 link mounts *rc4wd battery mount on front axle *NEW 8 cell batt,. mounted on front axle *alum. threaded internal sprung shocks,come with external spings and optional set of dampeners *rooster esc *matrix 60 turn motor that is soldered directly to esc for optimal performance * Traxxas 3 channel tx and Traxxas mini rx *Traxxas 2506 waterproof front and rear servos *front and rear servos plug into a central control that allows adjustable rear srteer *custom painted VW bug body *Wheels also have automotive lead weights in them |
01-04-2010, 07:58 PM | #8 |
Ya i took a quick glance at the ax10 thread, looks like a ton of info on there. So wht kinda class would i be in at a comp?
01-04-2010, 08:11 PM | #9 |
Stock axial goes under the 2.2 class...but I don't think rear steer is allowed in the 2.2 class comps...
01-04-2010, 08:12 PM | #10 |
Rock Stacker Join Date: Nov 2009 Location: Xenia
What they said, I just got my first AX10 a month ago and have been reading here ever since. I know nothing about RC and have learned enough here to step out and try. So much info I hope you have a good high speed computer connection.
01-05-2010, 05:32 PM | #11 |
Rock Stacker Join Date: Nov 2009 Location: Europe
hi - when I first started looking at crawling earlier this year i picked up a copy of this magazine from the UK, was a great guide to everything technical. http://www.radioracecar.com/crawler/ |
01-05-2010, 05:37 PM | #12 |
Quarry Creeper Join Date: Sep 2009 Location: redding ca
drop the rear steer and get a dig
01-05-2010, 07:26 PM | #13 |
| whts the best way to eliminate rear steer? I un hooked the servo n made up a link to the axle temporarily, its not real solid, and im havin issues with the turning radius in 2 wheel steer, whts a good servo? And my buddy has a nightcrawler and it flexs way better thn mine, any suggestions?
01-05-2010, 08:09 PM | #14 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
[QUOTE=DYNABOBBER;2207151]whts the best way to eliminate rear steer? I un hooked the servo n made up a link to the axle temporarily, its not real solid, and im havin issues with the turning radius in 2 wheel steer, whts a good servo? And my buddy has a nightcrawler and it flexs way better thn mine, any suggestions?[/QUO i run losi 4in shocks on mine with bent links got the new derlin plate on the way but right now its a flex monster |
01-05-2010, 08:13 PM | #15 |
| HERES THE PICS OF IT AS NOW, LET ME KNOW IF U C ANY PROBLEMS |
01-05-2010, 10:04 PM | #16 |
get some hot body rovers the white dots electronics look fairly good except the servo get a hitec 645ht servo they are about 35 and get the dig which helps in hard situations with better turning and and getting up obstacles so for now get the rovers and the servo that will help alot and then aventually a dna dig or the vanquish products dig............................. btw i have a nightcrawler and i have the different transmission rovers and servo and flipped front shocks and this thing kicks ass |
01-05-2010, 10:06 PM | #17 |
also its not about how good it flexes trucks can have an amazing amount of flex and suck at crawling you want to find the best center of gravity and and wheelbase and setup that works for you and to your liking
01-06-2010, 05:53 AM | #18 |
Cool, thx for the info, i was looking at the behind the axle steering kit, heard anything bout it yet?
01-08-2010, 06:10 PM | #19 |
yea my friend wants to get it it looks like it would be pretty sweet and work pretty good but i think that it might get stuck on a high center maybe just my 2 sence
01-24-2010, 07:48 PM | #20 |
Since my last post, ive totally changed this rig
