01-12-2010, 10:39 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Rocklin
| Pros and Cons
I figured this would probably be the best place to ask since most people would have started with a shaft driven rig before going to MOA. What are the Pros and Cons of an MOA rig? |
01-12-2010, 10:59 AM | #2 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
There are no cons;) especially with the bullys. You can't break them and they perform great. It's never the trucks fault with moa/ bully! More pros are. Narrow chassis, more power, using motor stall as an advantage to make climbs easier, having the option of running duel esc. No torque twist, adjusting rife height without giving up as much cg to make huge breakover climbs!!, A LOT less tweaking and tinkering bw runs. I haven't had my moa for long but these are some things I've observed while watch other moa and shafty drivers... IMO there is no other option when you want the best comp rig money can buy....
01-12-2010, 11:16 AM | #3 |
| That is kind of what I was thinking. I couldn't come up with a con but figured I don't own one so that is probably why. Even a well built LCC would'nt have the low CG and break over angles the bully does. Not seeing how they could comp in the same class.
01-12-2010, 11:18 AM | #4 |
Quarry Creeper Join Date: Oct 2009 Location: St.Louis
The only con I can think of is cost. MOA's are a bit more expensive. Not saying that you cant spend a load either way. I still think MOA is worth it. Once I get everything for my new Bully build my shafty will be a shelf queen or a scaler!
01-12-2010, 12:14 PM | #5 | |
Rock Crawler Join Date: Mar 2008 Location: lodi
this is actually false. startup yes shaftys are less expensive. go build an axial that will handel anywhere close to a bully and ur looking at atleast 2x more money. the moas are thought of as a higher cost because startup is more, the kits need to be upgraded or electronics need to be bought unlike a rtc or a rtr axial. but the shaftys out of the box cant touch most basic moa rigs. also its the driver. you can have the highest $$ rig out there but without the practice you still will get beat | |
01-12-2010, 12:38 PM | #6 | |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
I will also have to say clod stall starts as a con--but once you figure it out then its a pro. | |
01-12-2010, 12:49 PM | #7 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
I just built my bully for around $300. Granted i got some stuff second hand but still it was a load cheaper than my shafty. And works a ton better.
01-12-2010, 12:55 PM | #8 |
Rock Crawler Join Date: Jan 2009 Location: Boise
01-12-2010, 01:12 PM | #9 | |
01-12-2010, 01:14 PM | #10 |
01-12-2010, 01:20 PM | #11 |
the way i have used it in the past is almost like free wheel theres a split second where your front wheels will be searching for traction while the back wheels are stalled. when the front wheels do find some bite they pull and take the wait off the rear which is enough to end the stall and pull you up the slope. in some cases if you used dig to attempted the climb the lack of rear wheel turn could hamper the truck to climb when the front does find traction... another time i see it is when im climbing... the front will spin a little faster than the "stalled" rear end which helps keep me from tipping back.maybe not the best explanation but it makes sense to me haha hopefully we can get a few more responses on this or maybe a video. yeah you should watch some moa driving. you can see in some cases where the stall comes into play. another thing i think is if youre worried about stall its probably bc you havent driven an moa yet to see how much of a non issue it is |
01-12-2010, 03:11 PM | #12 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
The con to moa is I didn't just build one right off instead of wasting all that time and money on a shafty. We should have a poll on how many folks wish they had never started with a shafty.:-(mrgreen: I tell everyone to start with a moa But they all seem to go out and get a rtr then end up replacing everything and selling it for a moa.:?
01-12-2010, 03:13 PM | #13 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
con it don't have drive shafts
01-12-2010, 04:02 PM | #14 |
01-12-2010, 04:44 PM | #15 | |
01-12-2010, 05:04 PM | #16 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| That needed to be said again Biggest CON Ive Heard about a MOA is: Some people think there better than a shafty. SeCONd, the steering sucks on a Bully. Dont you have to spend like 2 hundred bucks on nuckles and shaft just to get almost good steering?
01-12-2010, 05:31 PM | #17 |
if u know any one with a dremel tool the bully can have 47 + degrees of steering... that doesnt really seem like a bad amount to me just gotta take some of the beef out of the knuckles and a little off the cvds. they are still super strong afterwards.
01-13-2010, 07:35 AM | #18 |
Newbie Join Date: Dec 2009 Location: Kansas City
Whats the differences on the Bully and the Berg other than price?
01-13-2010, 07:49 AM | #19 |
| From my understanding, Bully's are almost bullet proof out of the box. Bergs on the other hand are not. Bully's are heavier than Bergs. Bully's have went through several manufacturing changes due to customer response. I think its all a trade off between the two, I really dint think you can go wrong either way!
01-13-2010, 05:13 PM | #20 |
From what im finding the bully costs about $350 for the roller. Is the berg $600 for the roller????????
