01-26-2010, 12:33 PM | #1 |
Newbie Join Date: Feb 2009 Location: East Amherst New York
| gear lube What is a good gear lube to run in transmission and axles Thanks BOB |
01-26-2010, 12:43 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: Anderson
Mobile one full or semi synthetic is fine. Just make sure you don't get something to overlly thick. -Jason |
01-26-2010, 01:09 PM | #3 |
| lube That is what I was thinking. Do not want something to thick Thanks BOB |
01-26-2010, 01:23 PM | #4 |
Rock Crawler Join Date: Jan 2009 Location: Jacksonville FL
i use grease um lithium grease is great for me i use it in my tranny and my axles assuming your talking about rcs |
01-26-2010, 02:13 PM | #5 |
| grease Lithium grease is not real thick is it????? I have some here and will take a look at it. Thanks for help BOB |
01-26-2010, 03:58 PM | #6 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
I use high viscosity marine grease. Its not somthing to use to "pack" somthing full, but it works for a light application to everything.
01-26-2010, 04:52 PM | #7 |
Do not use white lithium, it dries out and gets hard fast. I use Lucas Red & Tacky, from what I get it's about the same as the mobile one mentioned above.
01-26-2010, 05:00 PM | #8 |
Hateraide Join Date: Dec 2008 Location: Mission BC
Shoot Team3Six a pm or goto his website and get his gearjelly the best there is |
01-26-2010, 05:05 PM | #9 |
Newbie Join Date: Jan 2010 Location: St. George
I use marine grease to. You can buy small tubes of it. It does better at repelling the water and things, so if you drive in water or mudd thats my $0.02 |
01-26-2010, 06:01 PM | #10 |
Pebble Pounder Join Date: Jan 2009 Location: Crestview
Penn Synthetic Reel Grease is what i use... i figure i have used it for years on my reels and no noticeable wear and waterproof...
01-26-2010, 07:06 PM | #11 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
01-26-2010, 07:10 PM | #12 |
Newbie Join Date: Jul 2009 Location: Southern Ontario
Anybody use wheel bearing grease? I have a small tub of it not being used for anything and I may use it on my bullys when I get them.
01-27-2010, 08:56 AM | #13 |
01-27-2010, 08:57 AM | #14 |
01-27-2010, 05:18 PM | #15 |
Rock Stacker Join Date: Mar 2007 Location: Alberta
I've been using bar soap on my gears in my race trucks for a few years, and I've started using it in my crawlers as well now and haven't seen any noticeable wear and everything still spins smooth.
01-27-2010, 05:31 PM | #16 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
01-27-2010, 06:18 PM | #17 |
Newbie Join Date: Oct 2005 Location: bfe
how often should one change the fluid? every 3000 miles? |
01-28-2010, 03:28 AM | #18 |
Quarry Creeper Join Date: Jan 2010 Location: USA
I was just shopping for grease as well. I ended up with a tube of Lucas Red & Tacky for about $4.00. I have not seen any negative reviews on it. The only product I have seen with nothing but positive reviews was the gearjelly. Even though it is made by rocksmith, Team3Six is a distributor for it. I probably should have bought it, but the Lucas Red & Tacky should be good enough for my needs. |
01-28-2010, 01:02 PM | #19 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
This is what I had at hand when I built my crawlers and it seems to work well: http://www.philwood.com/products/greaseoilhandcleaner/ Narly1 |
01-28-2010, 01:20 PM | #20 |
Quarry Creeper Join Date: Jun 2008 Location: Central KY
