01-12-2006, 07:56 PM | #1 |
Newbie Join Date: Aug 2005 Location: the sticks
| Tamiya Touareg crawler/trail rig. what motor to use?
I'll be using the stock 16 tooth pinion and i'm using it for crawling most if the time. Would it be too slow with a 55t lathe? Another question,what kind of maintenance does the 55t lathe motor require? Is it much better than a 27t stock motor? I was hoping I could get atleast 20 runs out of it before the performance started to drop then then I could just get another one. Thanks people!!! |
01-12-2006, 07:58 PM | #2 |
you should get 20 runs pretty easy. when you are done just send it to me . The maintenance is pretty low compared to most motors because of the low amp draw. it will be pretty slow, but pretty good for a crawler if you lock at least the rear diff. |
01-12-2006, 08:04 PM | #3 |
Thanks! Thats what I wanted to hear. |
01-12-2006, 09:04 PM | #4 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
It's still pretty quick (for a crawler) with a lathe motor.
01-12-2006, 09:41 PM | #5 |
I joined the Band! Join Date: Oct 2005 Location: NOYFB
65 turn works well.
01-12-2006, 09:59 PM | #6 |
How does the 65t compare to the 55t? how does it differ in performance and maintenance?
01-12-2006, 10:23 PM | #7 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Moved to Newbie. The 65t motor will be slower, have more torque and run longer. The maintenance will be the same. |
01-13-2006, 10:06 PM | #8 |
Rock Stacker Join Date: Nov 2004 Location: Kingston Ontario Canada
I've got 4 XC's, all with 55t lathes. Run time with a 3300 is, well, long.... I get at least a couple hours driving around the trials course and trails in my back yard. Its a bit slower than with the silver can, but much better throttle control and runtime. I must have 30 or 40 packs through my oldest motor and I haven't seen a drop in performance. Come to think of it, other than spraying it down with motor wash and sticking a drop of oil on each end, I've never pulled it apart. I wonder what the brushes and com look like... |
01-15-2006, 04:45 AM | #9 | |
Rock Stacker Join Date: Oct 2005 Location: Newbie general!!!
