Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Traxxas shocks on an AX10
Old 03-02-2010, 07:56 PM   #21
The Big Bores are killer, I've been running them for 4 years with no leaks or binding issues of any sort. I've run them in both droop and sprung configurations.
I use Associated shock bushings to mount mine; not a fan of the cap mod myself.
Depending on your chassis and set up you may need to shim them out a bit as well.
CreepyCrawl is offline   Reply With Quote
Old 03-03-2010, 02:58 AM   #22
What color springs do you run?
Kanine38 is offline   Reply With Quote
Old 03-03-2010, 06:08 AM   #23
I currently run a droop set up with RCP internal springs that I've had forever.
I'm not sure what the rate is since they don't provide that information, but they are very close to the TCS Soft internal springs.
Oil viscosities vary depending on the time of year (temps) but I generally use 80 to 100w all around; usually with a lighter weight by 10 up front.
