03-01-2010, 11:38 PM | #1 |
Pebble Pounder Join Date: Aug 2007 Location: Roosevelt
| electrical help
I just pulled my wk out from it winter slumber and turned it on when my steering servo turned all the way to the right. I have a traxxas tq3 controler with rear steer mod. Im not using the rear steer at the moment. any sugestions?
03-02-2010, 06:35 AM | #2 |
Newbie Join Date: Feb 2010 Location: mine run
try resetting the arm on servo |
03-02-2010, 09:03 AM | #3 |
I tryed it goes back to the right as soon as you turn the controler back on.
03-02-2010, 10:09 AM | #4 |
Rock Crawler Join Date: Sep 2009 Location: minnesota
make sure your trim is set correctly maybe...make sure the servo horn is centered correctly....
03-02-2010, 11:23 AM | #5 |
The trim does nothing no mater where you set it. I can hear the servo trying to turn but its gone as far as it can untill i shut off the controler.
03-02-2010, 12:04 PM | #6 |
Have another servo to test with?
03-02-2010, 12:22 PM | #7 |
Try hitting the reverse switch on your TQ3.
03-02-2010, 12:35 PM | #8 |
Quarry Creeper Join Date: Feb 2010 Location: muskegon
Try reseting your servo arm by turning it on then letting it go full lock like it wants to then while it's still on remove the servo arm and fix the alignment then reattach the arm to the servo. i had to do this with my buggie a couple times
03-02-2010, 07:53 PM | #9 |
I put my steering servo on my 3rd channel and it steers just fine so does that meen its my controler or is it the recever?
