03-11-2010, 12:55 PM | #1 |
Rock Stacker Join Date: Dec 2005 Location: Houghton
| Wiring Bec directly to servo
Been searching on here for awhile for proper wiring a bec to the servo instead of plugging it right into the servo. Does anybody have a wiring diagram or can explain it a little better than whats on this site? And if anyone knows what wires on my CKRC wiggle coorespond to the red,black,white wires on a futaba servo. Running a CC 10 amp w/ a sidewinder esc. Thanks for the help |
03-11-2010, 01:30 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
03-11-2010, 01:49 PM | #3 |
Quarry Creeper Join Date: Sep 2007 Location: Central Coast, NSW, Australia
This may help. Its using two BECs instead of one, but you can wire it the same. There is also a dig servo powered off the BEC as well, but you can ignore if its N/A. The M and F I've got writen there denote if there is a male or female receiver plug on the end of the wire - eg the two signal wires going from the servos to the Rx have male plugs on the ends. Last edited by LincolnBlack; 03-11-2010 at 01:50 PM. Reason: added details |
03-11-2010, 02:03 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
The only thing I would add is to make yourself a Y harness that connects between the BEC (for the + (red) and - (ground, black) wires), the receiver ( for the signal (white or yellow) wire) and the servo. That way you don't have to cut any of the servo or BEC wires or pull contacts out of connectors. Narly1 Last edited by Narly1; 03-11-2010 at 02:12 PM. |
03-13-2010, 08:54 AM | #5 |
Wow! what a difference, thanks for the diagrams. How hot does does the servo get while crawling?
03-13-2010, 02:18 PM | #6 |
No problem. Glad you could read it! Depends what you're doing with the servo as to how hot it gets. If you're constantly stalling it out by getting wheels jammed up etc, it may get too hot to touch - well, my 7955 does anyway. |
