03-15-2010, 11:49 PM | #1 |
Rock Stacker Join Date: Feb 2010 Location: Race City(Mooresville)
| chassis dxfs or dwgs
Ok, I was wondering i searched around and found the templates in PDF form these in particular http://offroader5.freeservers.com/Templates/ those are PDFs, I really don't want to buy a converter software that I won't use that often. Are these templates or any others out there in dxf form, I want to mess around with it and see what I can do. I know that you can modify the templates for most anything but are the hole layouts for HPI specific stuff? thanks for any help/direction. |
03-16-2010, 07:26 AM | #2 |
For what purpose do you want to convert them? I print them out, cut them out, and stick them to whatever material I'm using as a guide. As far as I know, they are all for an Axial, but can be modified to fit whatever you want. |
03-16-2010, 10:07 AM | #3 | |
technical i could just print it and measure and redraw, just being lazy i guess. thanks for the reply. | |
03-16-2010, 11:23 AM | #4 |
I opened the Manta template up in MS paint to do a simple mod/stretch to fit super class measurements. Since you are working with a simple line drawing it isn't terribly hard or time consuming.
03-16-2010, 11:53 AM | #5 |
Newbie Join Date: Jul 2009 Location: Archdale
If you insert the PDF as an OLE Object, you can stretch or shrink the PDF if you want. You can also draw over top of the PDF and reprint but you can't erase any item off of the PDF I don't believe. Doing the above makes the file hard to work with and run fairly slow though. |
03-16-2010, 03:40 PM | #6 | |
Thanks for the info. | |
