03-16-2010, 11:49 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Poway
| motor temp - how hot is too hot?
system: novak rooster crawler, 55t, 2s lipos some run time results in pretty warm motor temps. may be normal, but seems that it should be cooler than it is. NO I DO NOT HAVE A TEMP GUN. with the 'finger test' - usually after about 3 seconds of touching, it is hot enough for me to not want my finger on it anymore. it does not instantly scald my finger, but is certainly warm/hot to the touch... is this normal or too hot. and what is reccomendation? |
03-16-2010, 12:02 PM | #2 |
I think 160* is about as hot as you want to get a motor. Temp guns are fairly cheap now...Harbor Freight has them for a few bucks. I'm not sure what the guidelines are for the finger test. |
03-16-2010, 12:12 PM | #3 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
My 45T Novak Motor with a 2s Lipo 30c is never more than just warm and that is after running it for about 45min-1hour. Both my ESC and motor are just warm never hot. If your worried then get a temp gun.
03-16-2010, 01:27 PM | #4 |
esc does not get hot at all, barely warm. just motor. does this make a difference? i think my spur and pinion are a bit tight, it was like that when i got it and never corrected it (bought used), i'll adjust that and see if it makes a difference. any other advice? |
03-16-2010, 01:42 PM | #5 |
If loosening the mesh doesn't let you hold your finger on it for 5 seconds gear the pinion down until you can.
03-16-2010, 02:14 PM | #6 |
03-16-2010, 02:27 PM | #7 |
Less teeth for a lower gearing.
03-16-2010, 03:38 PM | #8 |
Did you advance the timing for more rpm? That increases the amp draw which can cause a hot motor as well.
03-16-2010, 04:34 PM | #9 |
03-16-2010, 11:24 PM | #10 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
Your motor should not get anything more than warm. Some motors if you hit 170 degrees or higher, the heat kills the magnet. The "heat touch rule" is 5 seconds, but your figures are very sensitive to heat, so it may not be nearly as hot as you think it is.
03-17-2010, 12:24 AM | #11 | |
The other way is to chuck the motor in a drill and hook a voltmeter to the pos and neg terminals. At zero timing the voltage should be very nearly the same. Adjust the endbell if it is not. | |
03-17-2010, 09:54 AM | #12 | |
so, is this bad? what is the advantage/disadvantage of advancing the timing on the motor? (other than additional heat) oh, also, someone mentioned that i may have delicate and sensative fingers when finger testing motor for heat (thanks for asking ) - no, i pretty much have the opposite, which makes me think the motor is pretty hot. i'll need to grab a little temp gun i guess. | |
03-17-2010, 03:11 PM | #13 |
03-17-2010, 03:23 PM | #14 |
Newbie Join Date: Mar 2010 Location: Yankton
I know when I ran nitro's, there was the "spit test" for heat. Any such thing exist for electrics?
03-18-2010, 01:15 AM | #15 |
It makes the motor go faster, but its a crawler, so why? Thats what gearing is for.
03-18-2010, 01:31 AM | #16 |
Quarry Creeper Join Date: Aug 2009 Location: Golden, CRAWLERADO
from what i was told when i was having overheating issues on my axial was if you cant hold your fingers on the motor longer than a few seconds its too hot. i knew mine was getting hot because of the burning electronics smell.
03-18-2010, 09:49 AM | #17 | |
i guess i had my head in my ass when i was asking about the timing and what it does. i can obviously see that with it advanced, it is faster in forward than it is in reverse. does it make more torque this way though, or is it only for wheel-speed? and adversly, is it decreasing my torque in reverse? (not that i'm doing comps in reverse - i'm just curious) thanks for the helpful information guys | |
