03-16-2010, 02:00 PM | #1 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
| adding weight to SLWs
i got some slw .7 on the way im thinking about adding maybe 3oz to each front after i drill vent holes in them. whats the best way to add weight with these wheels being so narrow? will a stick of tape weight be to wide to fit around it, maybe cut it in half? any suggestions would help |
03-16-2010, 02:11 PM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
The Great Planes lead weight is almost the same width as the .7's. I usually run abot 5-6 oz. on them, so you should have no problems.
03-16-2010, 03:08 PM | #3 |
5-6 up front any in the rear?
03-16-2010, 04:14 PM | #4 |
I use duck decoy weights and a Weiss compound hand shears (green handles) to cut in half or thirds a 2.2 wheel length full width = 6 oz, cut in half = 3 oz, cut in thirds 1.8 oz. you can custom fit any width wheel.
03-16-2010, 04:19 PM | #5 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
I used coiled fishing weight. It comes in 1lb coils and are roughly 1/4" lead wire. Works great, just measure, cut and wrap it around the wheel. It's about 4oz per wrap or so.
03-16-2010, 05:31 PM | #6 |
ya i used the coil weight on my stockers and used stick weights on my double phatties the coils gets to bulky for anything over the first coil
03-17-2010, 01:10 AM | #7 |
Pebble Pounder Join Date: Feb 2010 Location: Wenatchee
| wheel weights
I would just run to les schwabs and get u some of there wheel weights and they will fit long ways just have to bend them alittle but with lead its very plyable. i also sometime just use eletrical tape tape to secure them and it works great. |
