Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: MOA Wiring guide
Old 03-19-2010, 12:12 PM   #1
Default MOA Wiring guide
This is my first time doing any kind of wiring and I haven't been able to find a wiring guide.
All the obvious parts:
2 motors,
BEC
Servo
ESC/dig in one unit (Not out yet. . . and yes i know I'll be waiting for a little while)
battery
Thanks,
TC
TC09mini is offline   Reply With Quote
Old 03-19-2010, 12:16 PM   #2
Well, it really depends on this ESC/dig unit and how it needs to be wired. Also, what Tx and Rx will you be using? If stick, how do you want to control the truck (both motors on one stick, separately, etc)?
JeremyH is offline   Reply With Quote
Old 03-19-2010, 12:27 PM   #3
using the DX3E.
As far as the ESC/Dig its Novak's 2 and one unit.
Old 03-19-2010, 12:36 PM   #4
So you plan to use this:
http://www.teamnovak.com/products/m2_combo/index.html
If so, you can see how they wire it in this picture:
To add an external BEC, just solder it into the battery leads and plug it into the AUX port on your receiver.
Old 03-19-2010, 12:56 PM   #5
yes but w/ different motors. . . I assume it's not going to come completely wired. What I really don't understand is the BEC and servo. . . how that comes together. . . I can see that that one is completely wired so simply putting the wires to the esc I clearly can do. . . but please explain the BEC.
Old 03-19-2010, 12:58 PM   #6
prolly just over thinking this and just need to wait and see what I'm getting and it will make sense.
Old 03-19-2010, 01:01 PM   #7
Yep, you are overthinking it. The BEC is pretty simple to install. Some people wire them directly to the servo, and bypass the receiver, but here is how I wire mine:
I have never had a problem with mine setup like this.
Old 03-19-2010, 01:05 PM   #8
Just what I needed thanks!
TCV
Old 03-19-2010, 01:07 PM   #9
No problem. That diagram should work for your entire setup...just keep in mind that you'll have wires for two motors coming out of the ESC.
Old 03-19-2010, 01:10 PM   #10
"HOLLYWOOD"
Mini's Avatar
Here is how I wired mine just ignore the motor and esc part just look at the BEC wiring.
Mini is offline   Reply With Quote
Old 03-19-2010, 01:30 PM   #11
WNYRCRC
I really like this wiring. But I run a 3 cell lipo. Is the rx still going to get 11.1 volts. I'd so why couldn't you run two bec's. One to power the rx at 6 volts and one to the servo at 7.4 .
Raceaholic is offline   Reply With Quote
Old 03-26-2010, 09:00 AM   #12
Decided not to wait for the M2. Going with a rooster and a punk.
Old 03-26-2010, 09:18 AM   #13
TEAM MODERATOR
Reflection's Avatar
If you notice,the red wire coming from the ESC,goes to the receiver. The red wire coming from the BEC goes to the steering servo.
What this does....Whatever voltage/amperage your ESC's BEC pushes,that's what powers your receiver,dig and whatever else gets power from the receiver. Since most speed controls used push between 5-6 volts out of the BEC,you don't risk burning up the receiver.
Since the voltage in the Castle BEC is adjustable and the red wire goes straight to the servo,you can pretty much run whatever voltage you want to your servo. I have all mine set at 7 volts. Even though my servos are only rated for 6 volts,I've found upping the voltage a little,mine run a little cooler. They get woke up a bit as well and push a few more ounces of torque.
Upping the voltage,your at your own risk though.
Reflection is offline   Reply With Quote
Old 03-26-2010, 05:03 PM   #14
Is anyone using that novak daul motor esc.If so how is it working out for you.Do you still have clod stall or is it gone.
scram8 is offline   Reply With Quote
Old 03-26-2010, 07:26 PM   #15
sorry might be the wrong thread but would my 7955 tg handle 7 volts and could you guess the torque.
Grimreeper is offline   Reply With Quote
Old 03-26-2010, 07:34 PM   #16
TEAM MODERATOR
Reflection's Avatar
I was running that same servo on my Berg,at 7 volts. All I can say is it worked well for me. I know several others that have done the same. I put my 7955 on my rock racer and went to a JR9100 on the Berg. Still running my Bergs steering at 7 volts. The 7955 is rated at 333 oz. at 6 volts. At 7 volts,not real sure,but I'd guess somewhere closer to 400 oz. I don't really have anything to actually test that with,maybe someone else does?....
Old 03-26-2010, 09:39 PM   #17
Got Worms?
I'd get something else than a rooster. Get either the hh esc or a mamba. The rooster just can't supply sufficient voltage a moa and i think it has a high turn limit so you'll have to run super slow motors on a 2s
losikid is offline   Reply With Quote
