03-21-2010, 01:33 AM | #1 |
I joined the Band! Join Date: Mar 2010 Location: nashville,TN
| deans plugs
ok what are deans plugs and what is dig?
03-21-2010, 01:36 AM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: Cookeville
dean plugs are connectors that people use for battery's or for motors. a dig is used to make the front tires spin while the rear either locks or free spins or can make the rear spind and the front lock up or free spin.
03-21-2010, 01:55 AM | #3 |
| ok the "dig" thing is tht a must have i have a duratrax cliffy. proly wont do ne comps but i still want it to be awesome and go ne where p.s. thnx |
03-21-2010, 09:34 AM | #4 |
Pebble Pounder Join Date: May 2009 Location: South Gap
No, dig is not a must have. Especially if you're not going to be doing comps. It is a good thing to have, and helps a lot in certain situations, but it's not something you "need" in order to crawl well. If you were comping, you would want one, because it allows you to pull off more maneuvers which equates to less points. Deans plugs are high performance connectors. |
