03-24-2010, 08:27 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: coalmont
| leopards
trying to mount them on lnc wheels using the only foams I have stock rovers can't get them to stay anybody no a trick
03-24-2010, 09:48 PM | #2 |
Quarry Creeper Join Date: Sep 2007 Location: Central Coast, NSW, Australia
Use a roll of masking tape or something similar and place it over the tyre sidewall. You can then push the tyre (and bead) down into the wheel around the whole circumference at once. Holding the roll of tape (or whatever) down, you can fiddle the bead into its groove, and drop the ring on. Once you've got a couple of screws in, you can remove the roll of tape and do all the screws up tight.
03-24-2010, 09:57 PM | #3 |
Pebble Pounder Join Date: Aug 2009 Location: Snake Den
I have seen some people use the lids off of jars. The ones you can buy when you put your own stuff in jars with the removable center and it has seemed to work great. |
03-25-2010, 08:32 PM | #4 |
Quarry Creeper Join Date: Apr 2005 Location: LexVegas
Mason Jar lid!
03-25-2010, 08:47 PM | #5 |
Quarry Creeper Join Date: Jun 2005 Location: S Oregon.
I had a problem the first time, then looked to the side of me and found my Mountain Dew can was a perfect fit. You can get one side fairly easy, but the other side needs help. Put the wheel on the can and pull the tire down enough for the whole bead to seat into the beadlock (with some motovation from your free hand), then just put the outter lock on and it's done!
03-25-2010, 08:53 PM | #6 |
I can get them on they just won't stay
03-25-2010, 10:08 PM | #7 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
well if your bead is slippin then something is wrong bead's not in groove or somethingi had the same prob a long time ago i used a really thin bead of shoe goo, or rtv sealent it held the bead strong and i could remove it with no problems too
03-25-2010, 11:00 PM | #8 |
Rock Stacker Join Date: Jan 2010 Location: Chesterfield,Michigan
mason jar trick works awsome
04-02-2010, 10:08 PM | #9 |
You aren't getting the bead seated perfectly if it slips out. Keep taking them apart and re-beading them. I like to get the lock kinda tight, then maneuver the bead into the grove wherever it isn't completely seated.
