03-25-2010, 04:36 PM | #1 |
Newbie Join Date: Mar 2010 Location: H-burg
| Servo problem.
I put a new servo in my Losi NCR. There is a problem. The servo steers in the opposite direction than the controller. Would any one know the solution to this problem?
03-25-2010, 04:38 PM | #2 |
Pebble Pounder Join Date: May 2009 Location: South Gap
Your radio should have a servo reversing switch on it.. flip that switch and you should be good to go.
03-25-2010, 05:16 PM | #3 |
Quarry Creeper Join Date: Sep 2009 Location: Ukiah
make sure the reciever plug is in the right direction or reverse at the tx |
03-25-2010, 05:19 PM | #4 |
just switch the channel reversing switch dont mess with the rx plug because then it just wont work
03-25-2010, 05:20 PM | #5 |
Rock Crawler Join Date: Jan 2009 Location: Christchurch, New Zealand
You will need to check the programming on your controller. There should be a setting to enable channel reversing on the steering channel. This will achieve what you need. Cheers, Mike. |
03-25-2010, 05:21 PM | #6 |
03-25-2010, 05:45 PM | #7 |
03-25-2010, 06:20 PM | #8 |
Look on the top or your radio right behind the ant., flip the switch that says "st".
03-25-2010, 07:30 PM | #9 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
| yes... theres a mini micro button switch on the top embeded in the controller... there should be 2... switch the ST one over the opposite way it was at... |
03-26-2010, 09:57 AM | #10 |
Quarry Creeper Join Date: Oct 2008 Location: florida
Turn the remote around |
03-26-2010, 11:26 AM | #11 |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
| I just saw a pic on here where a guy was doing just that, but he was a lefty, and was holding the radio in the opposite hands, with the wheel facing the ground. Looked like it hurt. I would check into that servo reversing switch on the radio, as not all servos travel in the same direction for the given signal. If all else fails, they do make aftermarket servo-reversers. Last edited by cogfounder; 03-26-2010 at 11:37 AM. |
03-26-2010, 06:46 PM | #12 |
the switch worked on my controller! |
