03-29-2010, 09:00 AM | #1 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
| Rod end mod?
Okay, I think I need to ditch the stock Axial rod ends. I know some guys use Traxxas, but which ones? I would be replacing all the ends on the links, and probably the shock shafts as well. This is a pretty much stock AX10 basher, btw, just getting bound up a lot. |
03-29-2010, 09:08 AM | #2 |
I use either the Revos or the Jato Longs. I dont think either of these will be compatible with the stock links...they use 8/32" thread...
03-29-2010, 09:14 AM | #3 |
TMaxx rod ends will fit the 3mm thread, or you can just replace the Axial balls with Traxxas balls.
