04-10-2010, 07:31 AM | #1 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
| Shaft rubbing issue
OK, looking for a reasonably easy fix for this. I have a stock AX10 chassis, R2J skid with the inboarded lower link mounting and bent Axial lowers in the rear. I moved the axle end of the link to the inside of the inner tab to keep wheelbase on the longer side. Now I get some pretty decent rubbing on the driveshaft, gets better with compression, but at a vertically neutral position, the articulation is bad on that side. Is there a shaft that is narrower, not sure if MIP or someone makes one? Or some way to reorient the link? |
04-10-2010, 08:23 PM | #2 |
Newbie Join Date: Mar 2010 Location: Santa CRUZ
I also had some axle rub with my bent links I pushed them to the out side to clear the axle. some pics would be nice.
04-11-2010, 12:26 AM | #3 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Gotta say I only veiwed this because of the title. Are you using the square machined links?
04-11-2010, 12:32 AM | #4 |
Quarry Creeper Join Date: Sep 2009 Location: Divide, CO
A weekend in Vegas could cure most shaft rubbing issues |
04-11-2010, 12:34 AM | #5 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
04-11-2010, 01:18 AM | #6 | |
I guess I was just wondering if there were any shaft mods that people used to get around this issue. | |
