04-21-2016, 09:23 AM | #21 |
| Re: Understanding motor turns
lower KV = higher turns. brushed or brushless. Torque is affected in brushed motors as they get faster, right around the 2500kv mark it becomes evident that brush losses begin to dominate the power curve and brush wear accelerates greatly. You might notice we don't offer brushed motors faster than this, only as custom motors when customers are educated on the downsides. Torque is not affected in brushless motors when KV changes. Controller losses do increase as KV increases in the motor, but it causes only minute amounts of torque loss unless the controller temperature increases greatly. If higher KV is used AND geared down low enough to meet the wheelspeed of a lower KV choice, you will have more torque at the wheel, more power on tap, better low speed control, and better drag brake. There is no reason to buy a KV that is slower than wanted, but if there is geardown available it is wise to choose a higher KV and gear the vehicle down to suit. I would recommend 3300kv minimum. 3500 to 4500kv would be more suitable for 25mph in something like a bomber or wraith. The Puller Pro 540 in 3500kv is most popular for general use, and the 4500kv for rock racing. |
04-21-2016, 09:28 AM | #22 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Understanding motor turns Quote:
Kv(as in v subscript) is rpm per volt. Not to be confused with kV which is kilovolts. Unloaded Kv x input voltage = nominal rpms So you can calculate that out for a brushless then compare the nominal rpms of the two motors. Since the voltage in can be a variable you can also use this to calculate the difference between a 2s and 3s battery. | |
04-26-2016, 04:08 PM | #23 |
Quarry Creeper Join Date: May 2012 Location: Portland
just watch this has everything explained in understandable English..LOL https://www.youtube.com/watch?v=yjbc3PMKyGk |
02-10-2017, 09:24 AM | #24 |
Newbie Join Date: Dec 2016 Location: Here and there
Zombie still alive in 2017!!! Lol I have been noticing my stock motor getting weaking in my stock deadbolt and want to upgrade motor and esc. Im lookin at the holms hobby 35t but still have some questions. Whats with the 35t torque mater pro vs the 35t torque master expert. And further than that whats the difference in the straght leads vs the 90* leads and whats it mean by motor timing? And as for the esc, not sure wich one to get. I run on 2s and its mosly trailing with moderate crawling here in florida. Man i feel like such a newb. When it comes to going fast with brushless i know exactly what i need. Who figured slow would be so complicated? Lol Last edited by Summitbasher90; 02-10-2017 at 09:26 AM. |
02-13-2017, 06:31 AM | #25 | |
Rock Stacker Join Date: Dec 2016 Location: Las Vegas
thank you!!! | |
02-15-2017, 03:11 PM | #26 |
Newbie Join Date: Feb 2017 Location: Oly
Thanks for sharing |
10-16-2019, 11:35 PM | #27 |
Newbie Join Date: Mar 2019 Location: WF
I know this is a old thread that was rehashed and forgotten but I wanted to give it a bump as it has been the most helpful for me in starting to understand what the the different motor turns are for...
10-17-2019, 04:05 PM | #28 |
Pebble Pounder Join Date: Aug 2019 Location: Redlands, CA
2X for me, an old dork and newb crawler... have searched high and low and this popping up here catches me up to quality zombie-vintage 2010. Totally succinct description and to the point, especially having bought a used Torquemaster Expert 35T (540) to try in an Element Sendero. Thanks for your continued patience with us new guys whilst we search waaaay back for the unconscious knowledge. Now I’ll save this question for a new thread, but it’s, “Can the armature of a 35T be swapped with, say, a 27T or 21T armature of the same size can?” (EDIT: THE ANSWER TO THIS IS YES AND THEY ARE SOLD ON HH WEBSITE). I’ve been looking for a couple days now and learned many things but not this specific question. I’ll go post it now. Peace! Last edited by LincolnofDeath; 12-24-2019 at 09:22 AM. Reason: Update for easy info answer |
12-24-2019, 04:26 AM | #29 | |
Newbie Join Date: Jul 2017 Location: Windsor NSW
01-03-2020, 01:33 PM | #30 |
| Re: Understanding motor turns You can use a lower Kv with a two speed and still get a wide wheelspeed range. For two speed rigs I typically choose a 2200 or 2700kv, when I would have normally chosen 3500kv for single speed in the same use.
