05-03-2010, 07:21 PM | #1 |
Newbie Join Date: Mar 2010 Location: Princeton
| Going Brushless with my LNC what pinion ?
I plan to go brushless on my LNC with the Novak Goat Crawler Sintered Brushless System 18.5 on 2S what pinion tooth pinion would be best ?
05-03-2010, 08:59 PM | #2 |
Rock Stacker Join Date: Jan 2010 Location: beaver falls
8t if u want more wheel speed 10t
05-03-2010, 09:02 PM | #3 |
Which 18.5, the silver can (2700KV) or the black can (1650KV)? There's a huge difference between the two motors due to the rotor size.
05-04-2010, 07:24 AM | #4 |
Silver can 2700 KV
05-04-2010, 10:59 PM | #5 |
Well I was hoping someone that had ran that motor on a LNC would jump in, I ran that motor for a year and a half in my Axial and I've messed with LNC's a bit, but haven't ran the two together. I think about a 15 would be a good place to start, guys usually run a 12 or so in LCC's with that motor and the extra gearing in the LNC trans should let you run a bigger gear. Check for motor heat and gear down if it's to hot, if it stays cold and power is good you can go bigger.
