05-17-2010, 02:27 PM | #1 |
Rock Crawler Join Date: Oct 2009 Location: Greenville South Carolina
| Traxxas #2075 servo case.
Can this be used on other servos like taking all the internals out of a regular servo and then putting it into the waterproof servo case? http://www.amazon.com/Servo-Case-Gas...4127243&sr=1-3 Please has anyone tried this. as it would be very money saving. Last edited by THE CRAWLER KING; 05-17-2010 at 02:53 PM. |
05-17-2010, 02:41 PM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: YYZ
Instead of spending money on that... Why not spend that money to buy water proofing supplies ? Like... some grease & Plasti Dip Spray ? I think that would be a better solution. |
05-17-2010, 02:49 PM | #3 |
05-17-2010, 02:56 PM | #4 |
Ok so I'm gunna do it myself but I need your opinion on which is better the spray paint plasti dip like this one http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 Or the one where you dip it? Like this one. http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 And the grease can it be gotten at home depot or lowes or Ace/ What is the point of the grease? |
05-17-2010, 03:39 PM | #5 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
Get dielectric grease, open up the servo case and put it in there around the openings, problem solved.
05-17-2010, 03:41 PM | #6 |
Quarry Creeper Join Date: May 2010 Location: Plumas county
You know I h2o proofed a servo and it still holds up today after 9 months. Rtv silicon, electrical grease, and thick bearing grease. Take the case apart, line a thin bead of rtv on the edges of the case. Grease the servo output splined shaft and the case around it well. Smear electrical grease ontop of the breadboard and bottom. Put it back together. The teeth on the screws get a dab of heavy grease and the shaft before the head () get rtv. Tighten down but not all they way! Let it sit for an hour and then tighten down all the way. By letting it dry some before tightening, your creating a gasket around it. If it's tightened all the way before hand you can squeeze it all out and leave a spot not sealed completely. Rtv in a packet at autozone- 99 cents Bearing grease in a packet- 1.09 Electrical grease in yet agian the same packet- 99 cents. Go grab your supplies and have some wet weather fun! This can also be done to esc's |
05-17-2010, 03:51 PM | #7 | |
Yeha I already put the grease in it and just need to do the plati dip. I already have the xl-5 watreproof esc in my axial ax-10 and the rest of it is waterprof. and both my servos will be soon when I get back from Home Depot.."th umbsup" | |
