05-17-2010, 09:13 PM | #1 |
Newbie Join Date: May 2010 Location: Hillsboro
| All Steer Crawler
Is it possible to make an all steer crawler, where The Front and back Both steer. If so How well does it handle and how easy is it to make, Thanks
05-17-2010, 09:17 PM | #2 |
I joined the Band! Join Date: Mar 2010 Location: nashville,TN
yea im pretty sure yourself makes one if he tries hard enoughjk but i dont think so |
05-17-2010, 09:23 PM | #3 |
it can be done pretty easy but IMO dig will get you a lot farther, tighter turning than the 4ws (4 wheel steer), you can pull your front end down on climbs, use it to level and strech out your suspension (if 4-linked), and as well dig is comp legal
05-17-2010, 09:24 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
so your talking about a 4 wheel steer carwler? yes they are super easy to put togetaher they handle ok, they are great for bashing but not comp legal.. searchg for "four wheel steer" and you should get a tone of threads to read |
05-17-2010, 09:38 PM | #5 |
Quarry Creeper Join Date: Apr 2010 Location: Natchez
| Just picture a front axle on the back . You should read up on how to wire it up and different tx options . You can set it to steer opposite or you can have a switch that lets you reverse the rear steer so both front and rear turn the same allowing you to crab walk to the side . Check out the redcat rs10 adds and you will see how it works . IMO go for the dig though . They are comp legal and allow for some cool moves . You can lock the rear steer and remove the servo to compete . Also search vids on youtube for rear steer and dig setups so you can see just how they compare . |
