05-19-2010, 05:22 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: Lakewood, CO
| SWX chassis link lengths? I want to swap out the stock chassis for the SWX chassis and i need to know what lenghts are the upper and lower links and what ends to use if it matters. I just bought a AX-10 with aluminum links. a buddy gave me the chassis with no links and i want to get the same wheel base as stock ( I think). Any idea of which lengths to buy? |
05-19-2010, 05:45 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
bottom links are 74.5 and uppers are 60 |
05-19-2010, 06:16 PM | #3 |
06-07-2010, 04:01 PM | #4 |
is that the length of the link from bolt hole to bolt hole? I have been gone awhile, thanks.
06-08-2010, 12:00 AM | #5 |
If you buy the SWX new the links are included, no math involved... The one real problem with this chassis is binding, you need to replace the lower-link ball-ends going the chassis with the Axial bent ball-ends. As far as those new links you have, I recommend not running them, you'll get more money out of them if they are new (they won't work on the SWX chassis unless you extend your drive shafts; and if you compete you'll be too long.) |
06-08-2010, 12:43 PM | #6 |
i was given the chassis with out the links. I want to cut down the stock links.
06-09-2010, 09:21 PM | #7 |
Quarry Creeper Join Date: Jan 2009 Location: Langley, BC, Canada
Why not commission one of our vendors to make you some nice new bent links, out of delrin? Pretty sure R2J does them. I have bent delrin links on my SWX, and they work great.
06-10-2010, 03:20 PM | #8 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Ramset, I think I might have a used set of bent 3/8" Delrin links for the SWX if you want them. PM me Thanks for the props Mayze! |
06-10-2010, 08:05 PM | #9 |
No worries man. I know you have the skills to warrant the props. |
06-29-2010, 08:15 PM | #10 |
Skills, props and the generosity! Thanks for the free lower links R2j. With the lowers and the uppers i bought from you and the 4 link plate from Axial you suggested, the set up was awesome. The old familar park in Lakewood was boring to the 7 year old now. Now he is popping drive shafts left and right. thanks R2j. |
