Bec question???? If I use a high voltage steering servo,do I need to run a bec? I will be using a 8711hvt,3s lipo and a FXR on a moa set up. |
You don't need to, but a BEC will allow you to get the max votage to the servo. I believe the FXR is limited to 6v. Castle BECs are adjustable for whatever voltage you want to run. |
YES, you will need a BEC to run pretty much any steering servo when you are running 3S on an FXR. Actually just about any ESC out there will need a BEC when running 3S lipo except for the Holmes BR-XL Speedo. You can try it without one, but I guarantee that when you power it up and drive it, the first time you turn your wheels while on the throttle, your rig will stop dead in its tracks. |
