06-20-2010, 09:05 AM | #1 |
Rock Stacker Join Date: May 2010 Location: Anaconda
| Inova Delrin links
I would like to know if the Inova high clearance lower links will work on my LNC seeing as it is pretty much a LCC of sorts ? And what would I need on the end of these Inova links to make them work for my LNC mod ? A good source for the ends ? Thanks for any answers to so many questions. |
06-20-2010, 09:17 AM | #2 |
RCC Addict Join Date: Dec 2007 Location: On The Lake
A lot of people use Traxxas rod ends, Lee... I'll get you a part number if you need it I don't know if the high clearance links will work, either.. Maybe the medium clearance links would be better? |
06-20-2010, 09:18 AM | #3 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Yes they will fit, but the stock links are perfect for your application. The Losi links work best with their chassis. Should you chose to use the others tho, Traxxas, REVO rod ends are what you should get from your local hobby store. Or on line. (standard ones, not the long ones) Last edited by Krakker; 06-20-2010 at 03:29 PM. |
06-20-2010, 02:01 PM | #4 |
Thanks for the advice. Better/cheaper to find out these things beforehand from people who know what they are talking about than spend the $$$ and discover it is worse than better.
06-20-2010, 03:32 PM | #5 |
Something you could try is sliding BIC pen bodies over the stock links. It'll make'm slide over rocks like Delrin. 30 pens is like $3.'s at most office supply stores.
06-20-2010, 04:56 PM | #6 |
Ah. Tricks from the pros, love it. Thanks |
06-20-2010, 05:29 PM | #7 |
06-20-2010, 11:15 PM | #8 |
Thanks for the generous offer Matt but I will pass. These original LNC lower links may even be made of delrin for all I know and I thought the original LCC lower links were made of aluminum. I saw somewhere in my searching this site that the thought was aluminum didn't slide as well as the delrin links on the rocks so I may just stick with the stock links as suggested. Now I have seen the delrin skid it could be next on the list. I could be expecting too much from a LNC with the few mods I have added anyway and would be better directing any further mods/$$$ to another truck with a better crawling pedigree to begin with. Later Thanks again |
06-21-2010, 07:22 AM | #9 |
I joined the Band! Join Date: Mar 2010 Location: nashville,TN
ill take the links. free right |
