06-22-2010, 01:33 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: ny
| axial outdrives
ok here is my thing..... i get 3 minutes of run time on my axial crawler the outdrives look to be wore out and the driveshafts keep popping off are there outdrive better than the junk aluminum ones that axial provides |
06-22-2010, 01:51 PM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: kelseyville
i love these things i run them in all my axial trans http://tcscrawlers.com/Robinson-Raci...2-p-18069.html |
06-22-2010, 02:08 PM | #3 |
i was looking at that but i was hoping for something beefier
06-22-2010, 02:12 PM | #4 |
i think thats pleanty of beef, its hardened steel
06-22-2010, 02:18 PM | #5 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
06-22-2010, 02:20 PM | #6 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
The only way to get beefier is for the outdrives to get bigger. With the RR gear there is no need to go beefier anyway.
06-22-2010, 06:40 PM | #7 |
thank you to everyone that posted
06-22-2010, 07:03 PM | #8 |
Axial Steel Outdrives: http://www.axialracing.com/ftp/ax305...drive-set.html |
06-22-2010, 08:19 PM | #9 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
My kit came with the steel and they seem to work just fine. Wes |
06-23-2010, 07:24 AM | #10 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
06-23-2010, 08:14 AM | #11 |
the ones i have are the aluminum ones they wore out prematurly...the set screw isnt holding i swear they were made by integy...lol |
06-23-2010, 08:42 AM | #12 |
06-23-2010, 09:21 AM | #13 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I have always ran two set screws and locktite. No problems with the driveshafts coming loose/outputs stripping. The problem is twisting off the stock alum outputs! Steel ones will solve that! |
06-24-2010, 05:27 PM | #14 | |
Rock Stacker Join Date: Apr 2010 Location: Edmonton
+2. I had issues as well, seemingly minutes before it would pop off again, and always at the least opportune time. I have since broken the stockers on my SCX, and upgraded to some MiP's. A little red thread lock (which I can still get off later if I use heat), and I haven't had one come off since. It seemed like the blue wasn't cutting it with the stockers, and running 2 helped for a little bit, but in the end I think that the red is the key. And like I said, you can always use heat ( I. E. a soldering iron with all that plastic around it) to get it off later. | |
