06-27-2010, 04:51 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Kilgore
| Brushless question
I have a Traxxas VXL. Starting to build a scaler. If I added a 4:1 gear reduction, from RC4WD, and a 2.18:1 transfer case, also from RC4WD would it give me decent torque?
06-28-2010, 01:38 AM | #2 |
Quarry Creeper Join Date: May 2010 Location: Plumas county
That motor is pretty torquey when you look at it from 3s. I had one in my ax10 and it was fast. With your reductions it should be ok. But, get rid of vxl esc for sidewinder. I use my vxl for brushed motors, and the sidewinder/vxl motor combo is killer in any 1/10 rc!!! My opinion |
06-28-2010, 06:32 PM | #3 |
Quarry Creeper Join Date: Apr 2010 Location: Natchez
You will get more torque than you know what to do with . Watch for hanging the tires because you will break stuff ! With the VXL system you will still see decent wheel speed also . Only thing is , with the VXL esc you will see a little jumpiness on the bottom end . If you can trade off or buy new then go for a Mamba Max Pro . It has better options for crawling but still allows for low turn motors . I run a Mamba Max Pro with 4600kv on 2cell lipo and a 8:1 turn down . Let me just say torque and wheel speed are not a problem . I broke an axle just taking off at full throttle once on 3cell so I only run 2cell now .
06-29-2010, 05:40 PM | #4 |
Thanks for the input.
06-29-2010, 07:59 PM | #5 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
The mamba pro is a great ESC but overkill for 3s and a velineon motor. The sidewinder will give you the same benefits and be much easier on the pocket book.
06-30-2010, 05:05 AM | #6 |
| True , however the Pro is much more versatile and can be used with other RCs if you happen to have them . The sidewinder is great but the Pro is better . If its a budget issue go with the sidewinder . If you can afford it though , the Pro is the way to go . No turn limit gives you many more options . Just MHO .
