07-26-2010, 06:38 AM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: bowling green
| new esc or motor
im limited on funds right now but i want to upgrade my electronics. i have an ax10 with the stock esc and 55t motor.what would be my best option upgrade the esc and keep the motor
07-26-2010, 07:13 AM | #2 |
I would get a new ESC first.
07-26-2010, 07:43 AM | #3 |
Quarry Creeper Join Date: Apr 2010 Location: Natchez
I would buy an esc first . You will notice the motor perform better with a good esc so wait to buy a motor after the esc . You have lots of options here so do plenty of research . I try to buy with versatility in mind . A good brushed/brushless esc will allow different motor options for you . I would save more money and buy something really good incase you want to expand to other rigs or maybe volt up . I prefer the Mamba Max Pro because it is a do all esc and it can handle 80amps . Example , I am running two 27turn motors on my scaler and never even heat the MMP up .
07-26-2010, 08:41 AM | #4 |
could i get some model numbers of esc's that will work with the stock motor. im happy with the motor and how it crawls im just looking for some better control
07-26-2010, 08:59 AM | #5 |
What is your budget? For a lower budget, the Castle Creations Sidewinder will work quite well and can be programmed via your computer (quite a few additional options versus programming manually) if you also purchase the Castle Link. For a bit more money, the Holmes Hobbies Torquemaster BR-XL is an excellent ESC and also can be programmed on your computer using the Castle Link. |
07-26-2010, 11:23 AM | #6 |
im looking to spend 50 or less i dont do comps so im not looking for anything to fancy just looking for some better performance
07-26-2010, 11:31 AM | #7 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
An esc will give you far more performance benefits than a new motor.
07-26-2010, 01:06 PM | #8 |
$50....that will be a tough one. The cheapest I have seen the Sidewinder is ~$70: https://www.ssl-stormerhobbies.com/c...ns&pn=CCMM7701 |
07-26-2010, 01:42 PM | #9 |
Pebble Pounder Join Date: Dec 2006 Location: Weatherford
No first hand experience with it, but I've read good things about the RC4WD outcry and I think it's right around the $50 mark. Check out the classifieds and you might find a sidewinder for a good price, gotta be fast though as they don't hang around long in there.
07-27-2010, 12:49 AM | #10 | |
when I started I picked up a tekin combo esc/motor both for 100. they may be cheaper now,that was a couple yr ago. but the fxr has a small footprint,easy to adjust in the field WITHOUT a pc. and the customer service was good. I now have 4 trucks running the fxr with no problems, a real good value. you could buy used though and save some coin. | |
