07-26-2010, 11:59 AM | #1 |
Rock Stacker Join Date: Jun 2010 Location: Jersey Shore
| Good Battery and Charger?
would you recommend the tower hobbies battery and charger for my RTR honcho? has anyone ever used them? http://www3.towerhobbies.com/cgi-bin...=LXZEW1**&P=ML -Tower Hobbies AC/DC Peak Charger NiCd/NiMH............$19.99 -Tower Hobbies 6-Cell 7.2V 2000mAh NiMH Stick Std Plug............$16.99 |
07-26-2010, 12:05 PM | #2 |
Pebble Pounder Join Date: Sep 2009 Location: Rockport, TX
They will work if your goin' low budget. Might suggest a higher mAh like 5000...my .02 - enjoy ur new ride http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWZB8&P=7 |
07-26-2010, 01:00 PM | #3 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
If you can't go LiPo or don't ever want to, then the charger you mentioned should work fine. But I wouldn't strap a 5000 MAH NiMH battery to your rig as mfishr suggested because that battery is going to be heavy and will weigh you down. Instead, just get 2 2500MAH batteries and swap them out when one goes dead.
07-26-2010, 03:13 PM | #4 |
07-26-2010, 05:41 PM | #5 |
Rock Stacker Join Date: Mar 2009 Location: bay
SPECS: AC Input: 110V AC 60Hz DC Input: 11-15V DC, built-in lead with alligator clips Battery Types: 4-8 NiCd or NiMH Cells (4.8-9.6V, limited to 7 cells on DC) Battery Capacity Range: 600-6000mAh Fast Charge Current: 1, 2, or 4A linear (2A limit on AC) Fast Charge Termination: Peak detection Fast Charge Safety Timer: 90 minutes Peak Sensitivity: 8mV Auto-Trickle Current: 1/20 fast charge setting Controls: auto-start, switchable current selector LED Indicator: Red Output Connections: Built-in lead with standard connector Built-in jack for radio batteries Protective Devices: Solid-state reverse polarity and current overload Case size: 4.1 x 3.5 x 1.1" (104 x 90 x 29mm) Weight: 9.17 oz.(260g) yes this is a basic charge you my what to step up a bit. spend more now and not buy another charger in the next year or when you find out how nice lipo is. |
