12-19-2010, 09:54 AM | #41 |
I wanna be Dave Join Date: May 2010 Location: The east coast
looks nice. what did you use to make your rear lockouts?
12-19-2010, 09:58 AM | #42 |
Newbie Join Date: Sep 2010 Location: Reno
12-19-2010, 10:18 AM | #43 |
| i'm thinking the same thing. each picture i look at on the mrc threads seems to show the same size/shaped components. once my son starts breaking things my first choice will be to replace with losi parts. i'll keep this thread updated.
12-19-2010, 02:44 PM | #44 |
Newbie Join Date: Jun 2010 Location: bellingham
I picked up one of these this last week. So far I have lowered the body posts and put the heavy springs on the rear. also had to shorten the drive shafts about 3mm to get full upward wheel travel. I still need to lower my cg, remove axel guards, add wheel weights and lower the body some more. |
12-20-2010, 06:46 PM | #45 |
Newbie Join Date: Jan 2009 Location: washington
12-21-2010, 04:28 AM | #46 |
12-21-2010, 04:51 PM | #47 |
i'm really interested to know to about the losi parts. i broke an outer axle stub the other day, but my lhs didn't stock losi parts to try one. BTW nitrorcx.com has free shipping right now if anyone needs/wants parts. |
12-22-2010, 10:32 AM | #48 |
if i end up getting any losi parts i'll post it here. by the way, i've been reading up on ways to take the wheels off the rims. i want to add some weights up front but they are glued on. from what i've read there aren't many ways to do it without damaging either the tires or rims. if anyone looking at this thread have had luck, in particular with the maxstone 16, please post up your tricks. |
12-22-2010, 09:09 PM | #49 |
no good luck with removing the tires from the rims without some damage. i tried boiling them. so so. i did tear the beads a little. remember though, you only have to remove ONE bead per tire to either remove the foam, and/or weight the wheels.
12-26-2010, 09:07 PM | #50 | |
Rock Stacker Join Date: Nov 2010 Location: Ned
12-26-2010, 10:21 PM | #51 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
I've never tried it but I hear using the oven will work. Just don't put them in the oven while it's turned on. Preheat to 400º then turn it off and put the tires/rims in for 15 minutes. This is just something I found online, I've never tried it personally so attempt at your own risk. I've also heard boiling does work but it could take up to a hour. |
12-30-2010, 12:38 PM | #52 |
i ended up just peeling and cutting one side off. not pretty but they seem to have enough of a bead left to lock it in. for now i put in 1 oz of lead on each front wheel to get a little extra weight up front. i'm able to get up a traction board at 55 deg. not bad. it is still a little coggy at low speeds but i think that is just the way the brushless system i put in works. i did slap on a 11T pinion to gear it way down to help, which it does make the low end better. i'll get some pics up next time i have the camera with me. |
12-30-2010, 01:34 PM | #53 | |
Any Idea how much more wheel speed you have obtained? MY son and I are working on his. So far we have flipped the electronics tray 180 degrees, Reconfigured our batterie pack to fit on the front axel, Defoamed the tires (think it worked better in back with foam), shaved the axels,put one stiffer spring on the drivers side rear with more oil (no more major TT), greased everything and painted the body. We order the motor your using as well. | |
12-30-2010, 02:30 PM | #54 | |
i'm not sure how much more wheelspeed my son's crawler has now because i dial it down (he's a little trigger happy). i know it can outrun my venom creeper, but that isn't saying too much. i'll post some pics of my current setup later. | |
01-03-2011, 12:22 AM | #55 |
Rock Crawler Join Date: Oct 2010 Location: Reno
I'm really interested in your Maxstone16 build. I just bought one for me and for my 4 year old son. I modified mine to a 4 link already and it seems to be working great. I'm glad to see I found someone else on here that is building up on a 16.
01-03-2011, 04:29 AM | #56 |
i'm waiting until i get the new chassis to convert over to a 4-link suspension but i'm sure that will improve performance a lot. if you have some pics of your setup feel free to post them in this thread since there is no forum for the maxstones. i'd like to see how you set up your rig.
01-03-2011, 08:26 PM | #57 |
I would like to post some pictures for you. I have some. Stupid thing is I don't know how. Let me look around and see if I can figure this out.
01-03-2011, 08:47 PM | #58 |
It says down at the bottom of my "post reply" page under "posting rules" that "You may not post attachments". I don't know if this is because I'm a newbie or what. |
01-03-2011, 08:54 PM | #59 |
Post them on photobucket, then copy and paste the link into your post.
01-03-2011, 09:20 PM | #60 |
When you click on the picture you are trying to post, you are given 4 choices, you want to use the IMG code.
