01-29-2015, 01:55 PM | #741 |
Newbie Join Date: Jan 2015 Location: canada
| Re: exceed rc maxstone 16 upgrades and tuning?
I've shortened my housings so i dont have a problem with the pins coming out of the cup so i think the weak point will be the tranny melting down. Time will tell though. Now i just need a body for it so i can stop going easy on her. |
02-25-2015, 07:48 PM | #742 |
Ive added a body and shortened the wb to match. I blew the rear driveshaft, so now i'm running a drilled out mrc mip cvd in the front and a shortened punisher short shaft in the rear. Shocks are running 20 wt with secondary springs and bump stops on the shafts making them progressive ish. The cg is a little high as it has a heavy esc and battery and it has a little too much power so it drives a bit like a monster truck or southern mud truck. So far, I've broken an axle shaft, plastic spool, servo horn and bumper. |
04-25-2015, 11:45 AM | #743 |
Rock Stacker Join Date: Oct 2012 Location: GREEN ISLE MN
| Re: exceed rc maxstone 16 upgrades and tuning? Losi chubs lockouts and knuckles . yes it can be done |
04-25-2015, 11:47 AM | #744 |
| Re: exceed rc maxstone 16 upgrades and tuning? Aluminium skid |
04-25-2015, 11:49 AM | #745 |
| Re: exceed rc maxstone 16 upgrades and tuning? Carbon servo plate Ti drag link Spektum 6070 low profile. Servo |
04-25-2015, 11:51 AM | #746 |
| Re: exceed rc maxstone 16 upgrades and tuning? 370 heli motor .. Plenty of torque perfect peak rpm on 2s |
04-25-2015, 11:52 AM | #747 |
| Re: exceed rc maxstone 16 upgrades and tuning? Chassis |
04-25-2015, 11:54 AM | #748 |
| Re: exceed rc maxstone 16 upgrades and tuning? Losi alum parts Hot racing 1.9 |
04-25-2015, 11:55 AM | #749 |
04-25-2015, 11:58 AM | #750 |
[IMG]http://images.tapatalk-cdn.com/15/04/25/3e0a3b625b53b36f8c70f0cc388e7071.jpg[/IMG And this is what i build |
04-25-2015, 11:59 AM | #751 |
| Re: exceed rc maxstone 16 upgrades and tuning? |
04-25-2015, 12:05 PM | #752 |
| Re: exceed rc maxstone 16 upgrades and tuning? Carbon servo mount for standard width servo. |
04-27-2015, 05:47 AM | #753 |
Newbie Join Date: Feb 2014 Location: Munich
04-27-2015, 05:57 AM | #754 |
Yes. Not a direct fit . you have to sand the axle housing flush with the bearing. Be sure to keep it nice and square and hand sand and test fit. Take to much off and you'll have slop.
04-28-2015, 04:15 PM | #755 |
| Re: exceed rc maxstone 16 upgrades and tuning? Case mod needed for losi chubs and lockouts |
04-28-2015, 04:17 PM | #756 |
I also silver soldered the e-clip groove shut . broke one there. Weak point. |
04-28-2015, 04:24 PM | #757 |
| Re: exceed rc maxstone 16 upgrades and tuning? Finally!! 2nd one arrived today. Highly recommend the alloy . killed both long side with the heli motor upgrade .. Now on to the trans. |
04-29-2015, 04:14 PM | #758 |
Newbie Join Date: Sep 2014 Location: Victoria, Australia
04-29-2015, 04:23 PM | #759 |
05-13-2015, 07:26 PM | #760 |
