01-03-2011, 09:21 PM | #61 |
Rock Crawler Join Date: Oct 2010 Location: Reno
Maybe this will work. I'm really sorry to be clogging up the Thread with my attempts to join the conversation. |
01-03-2011, 09:24 PM | #62 |
Cool, I just received my first 16th scale Maxstone this afternoon, it's going to be scavenged for a scale build, but w/ just a few tweaks, it could be a decent little comp crawler. |
01-03-2011, 09:28 PM | #63 |
I think I got it. So here is another photo. This is how it currently sits. The little lipo is on the top because I don't have enough servo wire to get my battery and discharge protector down to the rear axle. I was looking for an extension but I'm super cheap (if you can't already tell, Exceed, custom motor mount, no name brand upgrades) and they are like $10. The lipo only cost me $5. I'm purchasing another 500mAh lipo that is half the size of this 1000mAh battery for $3 and just keeping it up top where I don't need to worry about wires in the springs and extensions. I will just add weight to the wheels to get some weight back in the rear. |
01-03-2011, 09:45 PM | #64 |
Here is some pictures of my 4 link next to my son's stocker. Bodies off so you can see what is going on. The stock is a little higher and flexes a little bit more. But the 4 link is super stable and feels so much more stable while driving. |
01-03-2011, 09:50 PM | #65 |
Just last night I moved all my son's electronics down and made a custom plate on the front upper links for the receiver. It is still the 3 link but it is helping the COG. I'll see what is next for it. By the way The only mod to the 3 link set up I have done it to install one stiffer spring in the left rear. it helps a ton with the TT but I don't like the way the 3 link crawls. |
01-03-2011, 09:57 PM | #66 |
Looks pretty cool. Hope to have pics of my little knockoff up soon. |
01-03-2011, 10:16 PM | #67 |
Cool. Would love to see more picture of what people are doing to these little guys.
01-03-2011, 10:26 PM | #68 |
I wanna be Dave Join Date: May 2006 Location: akron
01-03-2011, 10:28 PM | #69 |
01-03-2011, 11:19 PM | #70 | |
01-03-2011, 11:22 PM | #71 |
01-03-2011, 11:25 PM | #72 |
| Shocks are plastic and come w/ soft and firm springs, but they need heavier oil and spring tensioners. The tires are in no way comp quality, but they would be fine for scaling.
01-04-2011, 04:29 AM | #73 | |
I wanna be Dave Join Date: May 2010 Location: The east coast
the brushless is working out pretty well. when i let it run flat out (with 11T pinion) it is very quick. the drag brakes are strong enough to hold it on a 50 deg incline without moving, which i consider pretty good. i don't even think i have them set at 100%. the cogging is pretty minimum. even at really low speeds it has enough torque and control. i saw some comments about the shocks. yes, there are not the best and i will probably upgrade them someday but for now i'm more focused on the chassis and link geometry. one area i really want to work on is steering. pretty limited in stock form. i think some MRC CVDs and new knuckles are in order. i'm use to my venom creeper having almost 50 deg of steering! | |
01-04-2011, 06:59 AM | #74 |
Oh I'm so glad to hear that the brushless motor is working out pretty well. I think I will order one with my next order to hobbypartz. I totally agree with you on the steering. It has a terrible turning radius. The only thing that seems to help it out is that it is a 1.9 so it is small. LOL. All my shocks are leaking. But I'm in the same boat as you and I'll replace them eventually. I just what to get the truck up are running correctly before I start to tune and mess with small stuff. By the way, in the some of the photos of the 4 link truck it has white zip ties on the shocks. It is because I'm running Losi mini T stock springs in those pictures. the zip tie fills the gap created by the shorter springs. But they are very soft. I like the softness in the front and helps with front end flex. Thanks for the props on my 4 link. I did it very cheap. I used the longer 3 link bars from the factory 3 link suspension with the little middle and ends to the replacement servo linkage. http://www.nitrorcx.com/51c00-68014.html And then just a replacement servo mount. |
01-04-2011, 10:11 AM | #75 |
Rock Stacker Join Date: Nov 2010 Location: Ned
Finally more owners! Awesome Ideas! Can you show more pics of you 4 link mounts on the axel? Also why are you moving weight to the back mine flips over so easy when climbing that I put my battery up front and it really helped in climbing? I lowered mine also by a limiting strap from the frame to the 3link to suck it down but still hate the axel steers it self when flexing. |
01-04-2011, 11:17 AM | #76 | |
I was wanting to move my battery to the rear axle to help with lowering the COG. But with the LiPo being so light I'll just keep it up top. | |
01-04-2011, 01:16 PM | #77 |
mostly looking for how you attached the upper links to the axel/servo plate.
01-04-2011, 01:19 PM | #78 |
Also what did you use for your upper shock mounts? Did the 4link get rid of the TT? |
01-04-2011, 10:25 PM | #79 |
I hope this answers some questions of yours. Rear from the top Rear from the bottom Both the front and rear are the same. The front just has a servo sitting on top of that servo plate. *the buggy tires are on it because my son and I were goofing around with rock crawler tires on his buggy. |
01-04-2011, 10:30 PM | #80 |
As for the shock upper mounts. They are the stock mounts but flipped almost upside down. I cut up the whole battery tray if you are have trouble seeing what I did. I will be getting rid of this set up being that it lowers the truck more than I wanted. Also I think if I can get the springs to the inside edge of the TVP it will put the shocks more vertical which will bring back a little of my articulation. I'll post pictures as soon as I get that done.
