10-07-2010, 06:04 PM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| how do i connect the ESC, BEC & battery??
I have seen the article on this site relating to this topic and came up with this but wanna make sure its right before doing this. Dont want to cook anything!! Help appreciated!! OFF RECIEVER: B = N/A 1 = STEER 2 = ESC 3 = DIG 4 = ??? MODIFYING STEER SERVO FOR CC BEC: A. Cut the POWER/GRND wires from the servo. B. From the RECIEVER the only wire from this plug being used will be the signal to the servo C. The VCC/GRND from the steering servo will go directlly to the CC BEC component. **When this is all connected/soldered together you will have the VCC/GRND doing nothing from the Rx.** Power/Grnd from servo will go to a secondary plug (found one off a fried servo), this will run to the BEC. Last edited by SwampDawg; 10-08-2010 at 01:12 AM. |
10-07-2010, 06:18 PM | #2 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
| you can use channel 4 for whatever or use Bind for the same thing |
10-07-2010, 06:25 PM | #3 |
Quarry Creeper Join Date: Jul 2010 Location: Independence
i would also add that you should go to team3six website. very cool info there. electronics 101 is very informative.
10-07-2010, 07:32 PM | #4 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
I just orderded my BEC and thought I would just ask on this thread, since it seems the original issue is sorted, will most recievers handle the 7.whatever volts this unit can pump out? thank you.
10-07-2010, 07:34 PM | #5 |
ive seen the illistrations on this in several different forms, so i dont need another here. I am asking if the way i showed will work using a custom Y-Connector. please help me on this so i dont cook my stuff |
10-07-2010, 07:35 PM | #6 | |
both the power wires of the BEC need to be hooked up to the corosponding power wires on your power source..... refer to the drawings you've alteady seen. | |
10-07-2010, 07:44 PM | #7 |
hmmm does the power (+) not take the path through the BEC then through the ESC and back into the (-)BatterY?? |
10-07-2010, 09:48 PM | #8 |
10-08-2010, 12:22 AM | #9 |
Pebble Pounder Join Date: Sep 2010 Location: Lees Summit
Yep, that should do it. I just wired up my BEC tonight, basically just like that (but without the deans). The thing I did not really understand is where to connect it to the receiver. I put it in the AUX port, but it appears the BND port will work just the same. Is there any reason not to put it in the AUX port on the receiver?
10-08-2010, 01:19 AM | #10 |
jebus!! now im confused on the servo for the Dig unit now?? i had thought my dig servo was to be plugged into CH3 in my Rx, but after reading info im finding now that its supposed to be in "bind"?? |
10-08-2010, 12:37 PM | #11 |
your dig servo goes in the aux ch/ch 3 and bec in the battery/bind port
