03-17-2006, 02:05 PM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
| 2.2 Moabs
What is the best way to run 2.2 moabs on a tlt ?. is it best to run BB,s or wheel wieghts on the inside of the rim,s.? Also whats the best foam set up, Ive searched the forums and found lots of different ideas, but I would like to know you are all using , Thanks John.
03-17-2006, 03:07 PM | #2 | |
Your terrain is likely different than what other people crawl on, or maybe not, but it's going to be up to you to experiment. I can tell you this, full foams is not the way to go about getting good performance from the Moabs. Wheel weights are terrain dependant too. But nowadays with so many different trucks out there, you can see a ton of set ups with the weight balanced from moving the electronics on the truck to get it to perform the best it can. I'm not a wheel weight user. More cons than pros in my opinion. | |
