Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Axial Hub carrier I.D.?
Old 12-02-2010, 09:51 PM   #1
Default Axial Hub carrier I.D.?
Does anyone know the inner diameter of the hub carriers? Its the diameter of the hole that the axles slides into.
rock_blazer is offline   Reply With Quote
Old 12-03-2010, 06:38 AM   #2
On the lookout for Rocks
constantmotion's Avatar
The steering knuckle uses a 5x11 and 10x15 bearing....if that is what your asking.
constantmotion is offline   Reply With Quote
Old 12-03-2010, 07:43 PM   #3
I was actually refering the the inner diameter of this part http://www.rpphobby.com/product_p/ax30495.htm . I was wondering how big the hole is where the axle case itself slides into.
