12-30-2010, 04:04 PM | #1 |
Rock Stacker Join Date: Feb 2008 Location: middle of maine
| need drive shaft help
well im putting together a tlt axled ax-10 tranned tuber.... and i got a question about drive shafts im usen ax-10 drive shafts and there like 2cm to short are pede/rustler shafts longer? im trying to go for the cheapest drive shafts.... if there not any longer which driveshaft would be better... which is stronger? i guess ill have to buy ether set and cut up some shafts to make them longer.. thats y i ask which is stronger |
12-30-2010, 06:58 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
You can just put 2 female driveshaft ends in (one at the axle and one at the transmission). Then cut the male shaft off (ouch ) and glue it onto one of the female ends.
12-30-2010, 07:09 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Rustler/pede shafts are shorter, get some MIP's |
