01-11-2011, 03:40 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Trafalgar
| Cc bec help???
To get the full 6volts out of my CC BEC to my servo, i need to wire it where???? Thnaks
01-11-2011, 03:52 PM | #3 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
I'll help bro. check out this thread. BEC to Servo connector Mine is like this: |
01-18-2011, 07:06 PM | #4 |
So did you remove any wires from anywhere?? And where is the yellow wire to from the servo plugged in??
01-18-2011, 07:49 PM | #5 |
Jeep whore Join Date: Aug 2008 Location: Florida
also dont forget you need a castle link to program your bec to 6 volts, i beilive they come from the factory set at 5.1 or 5.0
01-18-2011, 08:00 PM | #6 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
From some vendors you can order your CC BEC pre set to whatever voltage you specify. Or your local hobby shop should be able to program it for free-mine did all 3 of mine in under a minute for free. Instead of using paper clips you can do a cleaner job by buying a pack of misc servo connector plugs and pins and make a clean coupler. BEC straigt to servo @ 6 volts makes a huge differance. Or higher if your servo is rated for it. |
01-19-2011, 04:39 PM | #7 |
Can u tell if it is set to 6v??
01-19-2011, 05:10 PM | #8 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
If its a new CCbec it will be set to 5.1 v out the pack. You can check what its putting out though by hooking it up to your battery and putting a multimeter on Pos & Neg to see what the output is. |
01-19-2011, 05:43 PM | #9 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
Mine was set at 6v when I got it, I hooked a Castle Link to it to change it and it was already set at 6v.
