01-16-2011, 02:43 PM | #1 |
Newbie Join Date: Sep 2010 Location: Woodward, OK
| Hitec servo horn problem???
Need help with Servo horn problem, I have the Hitec 7955 servo and the aluminum horn and I installed the Axial BTA on and the bolt and nut that came with the BTA will not fit in the hole of the servo horn, do I find a smaller bolt or can I drill out the hole to fit?? Just dont want to screw things up on my crawler. Please help out.
01-16-2011, 02:50 PM | #2 |
Rock Stacker Join Date: Feb 2005 Location: Mansfield
I just drilled the hole out to fit the bolt that came on my Losi nightcrawler. Seems to work just fine.
01-16-2011, 02:54 PM | #3 |
Thanks for the help
01-16-2011, 02:54 PM | #4 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
You're probably best off finding the smaller bolt - it's 2.5mm if memory serves. Having said that, I have heard of some folks tapping the servo output to accept 3mm bolts.
01-16-2011, 03:18 PM | #5 |
Rock Stacker Join Date: Dec 2010 Location: Easley
I also have the Bta kit from axial and drilled the hole out where the bolt would fit. havent had a problems so far with it |
01-16-2011, 03:24 PM | #6 |
Rock Crawler Join Date: Oct 2010 Location: pickens county
