02-10-2011, 09:23 AM | #1 |
Newbie Join Date: Jan 2011 Location: West Point
| Tire foam
I got a question on tire foam. I am running none in my front with about 8oz in them each. I think that I need some foam so they dont compress so much would anyone reccomend some foam that will fit around my wheel weights. I have weights they use on real cars lining the inside of my wheel.
02-10-2011, 09:37 AM | #2 |
RCC Addict Join Date: Oct 2009 Location: Council Bluffs
tires? wheels?
02-10-2011, 09:39 AM | #3 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
Also why are you running no foam and are they 1.9s 2.2s I just could see that much weight in 1.55
02-10-2011, 11:32 AM | #4 |
RCC Addict Join Date: Oct 2007 Location: gervais
it really depends, like others are saying, we need more details, but generally if you go with memory foams they do alright, and thats if you don't want to spend much, or if money isn't a problem, go with the crawler inovation foams, they got multipule selections |
02-10-2011, 12:02 PM | #5 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
I have to agree you can't go wrong with nova foams in your tyres , most of the guys at cANZ run the nova foams with sedona tyres and the work great for us
02-10-2011, 12:06 PM | #6 |
why wouldnt you run foams , if you can go with memory foam |
02-10-2011, 06:21 PM | #7 |
I took the foams out because the ones that were in it did not fit right with the weights and also I read some people liked the way they performed without foams after trying it out I dont think I do though.
02-10-2011, 06:23 PM | #8 |
O yeah 2.2 size axial rock lizards and just some plastic beadlocks
02-10-2011, 08:13 PM | #9 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
I'd say just trim out the stock foams to fit over the weights. I don't think there's much point in foam tuning with rock lizards since just about every other tire out there is just plain better. |
02-13-2011, 09:59 PM | #10 |
Newbie Join Date: Jan 2011 Location: Deltona
I cut a gear like pattern in my stock ax-10 foams. Worked well. Soft but not to soft.
