04-06-2006, 12:37 AM | #1 |
Newbie Join Date: Apr 2006 Location: san jo
| stainless steel chassis?
stainless steel chassis is this good material to construct my chassis or should i get the regular 6061 aluminum
04-06-2006, 03:06 AM | #2 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Steel is going to be heavier, but you may be able to use thinner material to cut down on the weight if you wanted. Steel accepts bending a little more easily (aluminum can tend to crack or break), but will be tougher to drill. Try searching a bit - I am pretty sure I saw someone make a chassis out of some stainless plate.
04-06-2006, 08:43 AM | #3 |
Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
If you do it right it should work, but as previously stated it will be HEAVY if you don't get rid of excess material.
