03-08-2011, 08:43 AM | #1 |
RCC Addict Join Date: Oct 2008 Location: 209
| xr10 or berg
what u guys think xr10 or berg. whats the pros and cons. is one better than the other and y
03-08-2011, 08:59 AM | #2 |
Rock Crawler Join Date: Jun 2009 Location: UK
03-08-2011, 08:59 AM | #3 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Personally I am more fond of the berg, I like the weight, I like the durability and its easy to set up. The xr10 is ok, but I don't like the horizontal front link mounts, the "BTA" set up wallows out over time, the tolerances on the gears are too tight and break bearings. The U-joints in the axle shafts wallow out. The axle housings start to bow then break and the stock wheels are way to wide as well the screws strip easily. I like the parts availability for the xr though, but sadly its need to much with my driving style. |
03-08-2011, 01:45 PM | #4 | |
Rock Crawler Join Date: May 2007 Location: Prescott
I have both a Berg truck and a XR-10 and compete regularly. From my experience the XR is the better buy since the only upgrades you need for durability with in reason is VP motor plates($40) and to get more steering you eliminate the slider and go to a solid tie rod($20) with VP knuckles($50). That is how I run mine and have had zero issues with it. To have a comparable Berg you will invest more money! It all comes down to what you want to get out of it. I left out a lot of details but that is it in a nutshell if you will. | |
03-08-2011, 02:27 PM | #5 |
Rock Crawler Join Date: May 2010 Location: San Antonio, TX
Just get a Xerg10 and problem solved!
03-08-2011, 02:55 PM | #6 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
03-08-2011, 03:05 PM | #7 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
This is a question that comes up on here and in my LHS. Ofcourse its going to be the XR. Anyone can build a kit, as long as you know what your doing. The cool thing is the rig can grow with you. I know ppl will say the gears break, blah,blah,blah. Mine are stock with over 100 hours on them. Half the time running 35t broods. I'm not very nice to the rig in anyway. I do have all the VP stuff for it and will say it is the reason the gears are alive at this point. I think the bergs are cool and all,but dont see a reason for someone starting out in MOA to have to take on a build like that. Get the axles, chassis, links, shocks, wheels, and so on separate. When you can have it all in the kit. Just dont do carpet digs and so on. That is the place alotof ppl are breaking gears, from what I see. Also, Rc4wd is come out with machined gears for the XR and they are only 39.99 per axle. Thats a nice price to bomb proof the XR.
03-08-2011, 03:15 PM | #8 |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
I run a berg and i love it but i would recommend the xr10. most of the comps i have been to lately most people have switched over to the xr10. I would check at your local comps and see what everyone is running because i don't care who you are someone has helped you before. the easiest way to get help is to run what the local people in your area are running. Both the Berg or the xr10 is capable of winning if they are setup and driven well. |
03-08-2011, 03:29 PM | #9 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
I have both and i like them each serves its own but when you go to any national comp the bergs still seem to be winning.I do bielieve that may change though real soon and second off look who sponsors most every national event Axial. support those who support our sport.
03-08-2011, 03:34 PM | #10 |
You know who has XR axles right now? Austin Dunn I see a big XR storm coming. |
03-08-2011, 07:02 PM | #11 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
but what dose he always take to the big comps berg
03-08-2011, 07:13 PM | #12 |
Not this year. Every video I see is a XR axled bodiless.
03-08-2011, 07:26 PM | #13 |
Rock Crawler Join Date: Feb 2010 Location: Chapin, South Carolina
What we need is some aluminum XR axles...
03-08-2011, 08:02 PM | #14 |
were r the vids at i havent seen none of them
03-08-2011, 08:13 PM | #15 |
| The second rig in the video is Dunns. His chassis design for the XR. Turkey crawl was his first comp with it I think. He rebuilt the axles on a flatbed truck bed in 30 degree weather the night before And kicked everyone's buttin the finals in the dark. Here is the video Last edited by Harvo; 03-08-2011 at 08:18 PM. |
03-08-2011, 08:42 PM | #16 |
looked sweet
03-08-2011, 08:51 PM | #17 | |
03-08-2011, 08:56 PM | #18 |
| He can beat everyone with a ax10 too, doesn't mean its the best.
03-08-2011, 08:58 PM | #19 |
Still, there is a method to his madness. He is using a XR for some reason.
03-09-2011, 06:10 AM | #20 |
Pebble Pounder Join Date: Sep 2009 Location: spearfish,sd
Berg all the way every xr I've been around blows up or has major issues and why would you want a plastic truck?
