04-18-2006, 01:17 PM | #1 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
| The Definitive Chassis Generation Thread
This post is to bring up differances in the generations: 1st gen: Pins in the hubs and shocks 2nd gen: Pins in the Hubs and shocks but upgrade pins in the axle 3rd gen: mounting plates on the hubs and screws on the shocks. Plastic Axle Couplers 4th gen: mounting plates on the hubs and screws in the shocks.Bump stops moulded into the steering hubs. Metal Axle Couplers If you have pics or further info .. post it up and i will update the thread. Last edited by TwistedXT; 04-19-2006 at 12:15 PM. |
04-18-2006, 04:52 PM | #2 |
Newbie Join Date: Apr 2006 Location: Dallas
Okay, I didn't quite understand the descriptions, but I started looking at mine. I took some pics, I'll try to update them later with quality ones, these were taken with my cell phone: 2nd Generation: 4th Generation: Last edited by Phoenix; 04-18-2006 at 05:13 PM. |
04-19-2006, 11:13 AM | #3 |
Newbie Join Date: Aug 2005 Location: Danville
Ok broke the rear axle in my first jeep so I went and bought another while I wait to get this one fixed under warranty.Both are early(1st gen.)chassis with pins in shocks.But there were some differences. 1)Boots over wires going to rearends.One has black,one has clear. 2)Wheels bolt on differently.One has a black plastic spacer with two prongs around the screw.The prongs fit into slots on the ends of the axle.The other is just a screw into the rear axle.This one doesn't have the slots in the ends of the axle.The wheels are also different.The one with the spacer has a larger hole in the center of the wheel to allow for the spacer around the screw.The other has a small hole just big enough for the screw to pass through.Hope that makes some sense. Anybody know if these are different gen or just a variation of the 1st gen? |
04-19-2006, 11:37 PM | #4 |
Rock Stacker Join Date: Apr 2006 Location: Mt. Pleasant
I have metal couplers in mine but dont have the bumpstops............what gen. is mine?? |
04-20-2006, 04:01 PM | #5 |
Quarry Creeper Join Date: Jan 2006 Location: PNW
1st Gen - Pins to hold axle together, Riveted shocks - cannot tell 1st from 2nd gen unless you take axle apart 2nd Gen - Plastic Axle Couplings, Riveted Shocks - cannot tell 2nd gen from 1st unless you take axle apart 3rd Gen - Metal Axle Couplings, Screwed on shocks, plate to strengthen knuckles, draglink attaches to knuckle with a threaded nut rather then another rivet 4th gen - metal axle couplings, screwed on shocks, plate to strengthen knuckles, draglink attaches to knuckle with a threaded nut rather then another rivet, steering stop molded into knuckle to keep hub socket (or whatever) from gouging into the stub shaft. Last edited by Chuki; 04-20-2006 at 04:05 PM. |
04-20-2006, 04:04 PM | #6 | |
04-30-2006, 04:39 PM | #7 |
Pebble Pounder Join Date: Nov 2005 Location: South Range
My buddy took the motors from his jank 1st gen and put them in his replacement chassis. The old motors in the replacement chassis go way better than the replacement chassis ever did. I'm not sure whether he used the new or old belts though. So, I am going to assume that they lessened the power of the motors in the replacement chassis to reduce axle breakage. I believe replacement chassis were 3rd gen, but I'm not positive, and I don't feel like unpacking mine to look for steering stops. Christian
05-01-2006, 05:14 PM | #8 |
Rock Stacker Join Date: Apr 2006 Location: KC
So I know this might sound dumb, but is the 4th gen the best so far? Sometimes companies f-up when they redesign. Also, is the scorpion chassis different than the jeep chassis. my 3rd gen jeep doesn't have as much flex as my 4th gen scorpion. If I put the jeep body on the scorpion chassis, the front tires rub the fenders at full flex. They never did that on the chassis that it came on Last edited by kcmudbug; 05-01-2006 at 05:17 PM. |
05-02-2006, 09:18 AM | #9 |
its kinda hard to determine which chassis are better than others... on the 4th gen, the bump stops in the hub dont alow the axle to pop out, and the belts are alot looser which means that the belt will slip before axles break. The chassis basics have all stayed the same... shock mounting points and the overall shape has ot changed at all... yet anyway. Who knows what kind of a chassis the bronco body will be sitting under.
05-07-2006, 10:11 PM | #10 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| 4th
Mine is a fourth gen. It has no bump stops.and it brakes easy .Mite as well only have low gear ,in hi it won't do any thing. I have alread oringed it. It rolled and broke the rear plastic NO fix avalabel. My next thread will be how to 4 link your nylint.
05-07-2006, 10:47 PM | #11 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
wurster, sorry to bust your bubble but DONT have a 4th gen.......
05-10-2006, 11:42 PM | #12 |
ok wtf is up here? i have my 3rd gen and my 4th gen sitting here side by side comparing them......they both have the metal couplers, the only differences i see are the colors of some of the plastic pieces...... |
05-11-2006, 06:02 AM | #13 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
the chassis look the same but i guess are not obviously, but its confusing getting parts
05-13-2006, 05:42 AM | #14 |
i got a hub for 2nd gen axle and i got the lastest editon and once i got the rivets out the new one installed just fine
05-17-2006, 12:07 PM | #15 | |
05-17-2006, 12:26 PM | #16 |
i know all about the bumpstops and stuff, but both my 3rd gen and 4th gen have metal couplers in the axles.....
05-29-2006, 11:29 AM | #17 |
well fellas, i found another difference......the 4th gen circuit boards are complete different..... wish i had a camera, but i dont.... |
05-29-2006, 01:54 PM | #18 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
how are they different? are controllers interchangable between them? -Dalton |
05-29-2006, 02:31 PM | #19 |
yes, the same controller works on my 3rd gen and my 4th gen.... the big board on my 4th gen is actually a big board and a small board with the black boxes mounted on the smaller one.....i didn't look at it to close, i just noticed it and posted as i was putting it back together.... |
05-29-2006, 06:41 PM | #20 |
Rock Crawler Join Date: May 2005 Location: Minnesota
are these the bump stops on 4th generations? |
