![]() | #1 |
Newbie Join Date: Mar 2011 Location: SoCal
im new to all this and am trying to adj the speed control setting mainly the drag brake. i have the link and downloaded the program,but cant seem to find where to plug it in? the only spot i see remotely possible is on top but there is only 2 pin holes not 3 ? do i need to take the case apart? thanks for any help
![]() | #2 | |
Rock Crawler Join Date: Dec 2010 Location: Beaumont Tx!
| ![]() Quote:
![]() | #3 |
um... theres nothing to plug into on the receiver either ? why would it plug into the receiver to adj settings on the speed controller?
![]() | #4 |
Defy Gravity ![]() Join Date: Nov 2009 Location: wells, mn
you use the wires that would normally plug into the receiver to adjust the settings, need the castle link usb programmer to do so. just pull the plug out of the receiver and plug it into the castle link as per directions on the link, don't get it backwards.
![]() | #5 |
![]() | #6 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Have you got the castle link dongle to hook it into you computer? If so that is what the esc's RX's wires plug into. Then a USB cable hooks the dongle (which your esc is hooked to) into your computer. |
![]() | #7 |
Thanks guys I think I understand now.it threw me off cuz the pic shows it going into the actual speed control box, so I was looking all over the box!! Then when you said it goes into the receiver that really f@cked me up! Never thought about the harness plug from speed control going into receiver. Thanks again guys. When I get home from work I will see what damage I can do!
