11-16-2011, 06:58 PM | #1 |
Newbie Join Date: Jan 2011 Location: union
| Scaler snow plow?
Anyone know if there is any website or anything that sell snow plows for 1/10 scalers or if there is anything on the web that shows how to build them? Thanks
11-16-2011, 07:24 PM | #2 |
Pebble Pounder Join Date: Jan 2006 Location: Knoxville,TN
Here is a few pics of the ESP that was for the Clodbuster , and look @ the 1:1 for more pics . Original CB plow? |
11-16-2011, 08:01 PM | #3 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
man you guys are starting early with this seasonal topic. check your search feature out, it's kinda cool and comes free to all that register here at RCC. what a bargain. SNOW PLOW SEARCH RESULTS<<---------- Click your mouse on that green part. now you can build your own. |
11-17-2011, 02:51 PM | #4 |
11-20-2011, 08:55 PM | #5 |
Rock Stacker Join Date: Jul 2011 Location: Land of the Lost
11-20-2011, 09:59 PM | #6 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| my honcho here's my plow i made. granted its not done yet but it works for the most part. i thought i did a write up on my thread on how i made it but i will explain it again because it was super easy to build. i used 2 upper control arms from a nitro savage. took a chunk of 3" PVC pipe measure how wide you want it, cut it, then i eye balled the middle of the pipe (you can measure if you want) and cut it in half lengthwise. im currently using a black big ass paper clip to hold them onto chassis. then took 2 little L shaped pieces of metal drilled a hole threw plow and bolted the brackets on and one end of the plow mount to the little brackets. then i tested it to how it did, it flips forward too easy so i made some braces from the plow to the mounts to stiffen it up and screwed them into place.. then took a chunk of jack chain im using to build tire chains and took out the 2 top screws from the braces fed the screw threw the chain and bolted it back up, this will be my plow lifting point for my winch. since i stiffened up the plow end with braces, when the plow hits something(nail sticking up from the patio) the plow stops and the truck doesnt and truck drives ontop of plow so right now other than figuring out how to stop that and get my winch working the plow is usable. still want to add a few things to it but it works for now. |
