12-29-2011, 02:35 PM | #1 |
Rock Crawler Join Date: Mar 2009 Location: East TN
| tight turnin
I was wondering what is a good setup for axial axles to get them to turn more. My scaler doesn't turn very tight, at all. Before I start sinking money I was hoping to get some advice. Thanks!
12-29-2011, 02:40 PM | #2 |
Pebble Pounder Join Date: Sep 2011 Location: edgewater
| Re: tight turnin
Before you do anything look at your controller and make sure ur steering adjustment is turned all the way up other
12-29-2011, 02:52 PM | #3 |
| Re: tight turnin
i did. it is. I still have the plastic knuckles and such and am going to get the metal/alum. stuff. But, I dont know what to get? anything make a difference or do I need to get vp 8 degree stuff. thanks
12-29-2011, 03:24 PM | #4 |
Rock Crawler Join Date: Aug 2011 Location: dallas
| Re: tight turnin
Or you can go w the axial clockable c hubs Part Number: AX30495 , high clearance nucklesPart Number: VPS01171 , but you will need cvds and i think these will work if not mip make some bad a$$ ones Part Number: AX30464
12-29-2011, 04:37 PM | #5 |
| Re: tight turnin
Thanks! Can you explain clockable and what are the "8 degree" VP parts?
12-29-2011, 06:18 PM | #6 |
| Re: tight turnin
the clockable alow you to roll your axle fwd to change pinion angle where you driveshaft goes into the axle or rotate back and your wheels will steer at an up angle vs flat if you get what i mean
12-29-2011, 06:19 PM | #7 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: tight turnin
clockable gives you the ability to change caster. 8 degree changes king pin angle to reduce scrub.
12-29-2011, 06:42 PM | #8 |
| Re: tight turnin
I see. whats scrub? and.... whats zero acherman. Thanks a lot for the help.
12-29-2011, 10:48 PM | #9 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
| Re: tight turnin
All these put together will get you turnin so tight, you'll rub your links! (Oh Yeah, and maybe some bent steering linkage to clear your pumpkin) VP Chubs VP 8 degree Chubs VP Knuckles VP 8 Degree Knuckles Super 300 CVD's! Super 300 Axial CVD's for Axial AX10, SCX10*-*Driveline Parts: Axles and axle parts*-*-By Truck: Axial AX10 Scorpion, SCX10, Honcho*-*The Crawlers Store LLC |
12-29-2011, 10:54 PM | #10 |
| Re: tight turnin
Forgot to mention over drive gears in the front axle, or under drive gears in the rear axle. (Both if you want) They will help you turn sharper and climb better. Axial Racing - AX10 Scorpion Optional Ratio Gear Sets |
12-31-2011, 12:10 AM | #11 |
| Re: tight turnin
Can you explain how the 8 degree and zero acker stuff works? I read the acher stuff from vp on wiki. but I got ... lost.
12-31-2011, 09:35 AM | #12 | |
| Re: tight turnin Quote:
It will add caster to your current set up. Which in turn will make your rig more stable at higher speeds,allow you to adjust proper pinion angle while keeping caster in the system.Another benefit is with the inclination and caster your tires will not get into your links or shocks as much if at all if that has been an issue. You also gain the strength benefits of the aluminum. So basically, you can clock your axle to get your driveline up and away from the rocks, all while still keeping a good steering angle. (It wont steer into the ground). | |
12-31-2011, 10:46 AM | #13 |
| Re: tight turnin
you are refering to the clockable stuff, correct?
tight turnin - Similar Threads | ||||
Turnin' and burnin' (The budget build) | Turn'Nburn | Axial XR10 | 17 | 04-25-2011 05:52 PM |
turnin a nitro savage into a crawler... | suspekAE | General Crawlers | 14 | 05-04-2008 08:39 AM |
Tight? | HPI_Savage25 | HPI Wheely King | 7 | 03-20-2008 10:57 PM |
Tight Squeez Going Through Changes | DirkDigler | Tamiya Txt-1 and Juggernaut | 5 | 03-11-2004 02:38 PM |
