07-16-2006, 01:04 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: MEDFORD
| tlt axle question
is it possible for the axle to come unlocked with use, if it is locked with hot glue? any help would be great. |
07-16-2006, 01:13 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Yes, the hot glue will give away over time. Fill it with JB Weld.
07-16-2006, 01:13 PM | #3 |
It can losen up some if you twist it hard enough. Are you trying to take the glue out or what?
07-16-2006, 02:28 PM | #4 |
no the last time i was crawlin the left rear when lots of load was put on it would stay still and the other wheel would spin like a open diff would. i didn't build the axles so i wasn't sure if the hot glue locking could come apart or not. since i didn't build the axles should i have to take it apart, do i need to put oil or grease back in when i am done or are they run dry? and what kind of oil or grease should i use if i do? thank you all RYAN |
07-16-2006, 02:35 PM | #5 |
Just apply a little grease to the ring and pinion gears. Any type of grease will work.
07-16-2006, 02:54 PM | #6 |
cool thank you
07-16-2006, 04:23 PM | #7 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
micro goat might let you use his vaseline.
07-16-2006, 05:08 PM | #8 |
i don't know you think its that tight in there |
07-16-2006, 05:15 PM | #9 |
Rock Crawler Join Date: Feb 2006 Location: jacksonville beach
dang i just went through all the trouble to lock em with hot glue like 5 minitues ago !!! im just not ready to commit to jb weld... lol
07-16-2006, 08:07 PM | #10 |
alrigth my jb weld is drying. i must have really put that axle in a bind cause i broke loose jb weld any ways just waiting for it to dry thanks for all the help everyone |
07-16-2006, 09:37 PM | #11 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
are you sure you didnt stip the splines?
07-17-2006, 12:36 PM | #12 |
yeah i allready took it apart and fixed it, the guy that built the axles just didn't use very much jb and it broke loose i checked every spline took everything apart and cleeaned it up then rebuilt and jb welded it all back together. when i took the diff apart the top gear just fell off and you could see where the jb broke loose
07-17-2006, 01:21 PM | #13 |
Pebble Pounder Join Date: Jun 2006 Location: GreenWood lake
i fount out you can also screw the diffs together if its breakin apart
07-17-2006, 01:46 PM | #14 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
My junk is JB'd and it'll slip a bit while wheelin, but it's the play in the Ring & Pinion not the locker. I go thru them after about 6 months or so.
