07-18-2006, 06:34 PM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: Albuquerque
| Locking Diff
Well after trying hot gule and testing on flat serfice it came un locked so... i am think of jb weld or gorrila glue and thoughts?
07-18-2006, 06:53 PM | #2 |
Pebble Pounder Join Date: Jun 2006 Location: GreenWood lake
be carful with gorilla glue cause it EXPAND SOMETIMES ALOT. But otherwise gorilla glue is great I am not liable for any overamount put put a little NOT ALOT |
07-18-2006, 06:56 PM | #3 |
Quarry Creeper Join Date: Mar 2006 Location: TAOS NM
dude why dont you just jb weld it its easy and fast and strong .
07-18-2006, 06:59 PM | #4 |
Quarry Creeper Join Date: Jun 2006 Location: BUILDING A CSC-1 in south mississippi
i agree gorrila glue is great but only but like a third in the diff cause it expands but is tough, jb weld is also good and strong but have no experience with it.
07-18-2006, 07:04 PM | #5 |
Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
jb weld it
07-18-2006, 07:08 PM | #6 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Hot glue works fine for me. You must have done something wrong. Like crawlerman said, you have to pack the entire diff full of it, and then quickly assemble the axle shafts. One plus with hot glue is that you can easily heat the diff up to remove the components to service the diff. If you use JB weld, all the parts are fused together permanently, so if you break an axle or strip a ring gear, you have to replace the ENTIRE diff and axle shafts as a whole, where if you used hot glue you can tear it down and replace just the broken parts. |
07-18-2006, 07:30 PM | #7 |
Quarry Creeper Join Date: Apr 2006 Location: Gervais
^^ not really. You can force it to ajust if it is still warm easily.
07-18-2006, 08:38 PM | #8 |
i did the hot glue fast like where i brunt my self but if work for a wile and then i loosend so i will try gorrele glue and if that fails jb weld
07-19-2006, 07:40 AM | #9 | |
07-19-2006, 03:00 PM | #10 |
If You Dont It Turns Like A Rubber And Wont Stick But If You Do It Fast It Has Time To Stick To Each Other.
07-20-2006, 08:34 AM | #11 |
oh yeah DUH i just thought it was a special technique
07-20-2006, 10:06 AM | #12 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Am I the only one that pegged my diffs? It's pretty easy and strong as well.
07-20-2006, 10:26 AM | #13 |
how do you peg you diff?
07-20-2006, 10:43 AM | #14 |
You drill 3 holes in the crown gear, cut 3 rods to the correct length (the width of one of your planetary gears) and push them through the 3 holes you made. They need to be a very tight fit or they'll work loose and damage your crown gear. You don't have to do 3 pegs, that's just what I did. |
07-21-2006, 12:08 PM | #15 |
have any pic?
07-21-2006, 02:11 PM | #16 |
Not yet but if mods permit I could make a walkthrough? hint hint |
07-21-2006, 02:23 PM | #17 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
I used 2 part epoxy purchased from the dollar store. you can see it in the picture above the diff parts. It set up hard in like 10 minutes, left it to cure for 24hours. |
07-21-2006, 02:51 PM | #18 | |
