06-04-2012, 09:40 AM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: Sedro-Woolley,WA
| Need to understand the hole dual engine setup?
hey guys im sorry im new to the xr10 and my other crawler seems to be a little more simple.. so the front axle has the transmision set up to them? both axles looks like that. then the motors you can 1 or 2? So im getting this kit in 2 days and im going to need to get just electronics for now. i really like savox servos there the best. what motors and other electronics should i run? thanks guys i really! appreciate the Help! |
06-04-2012, 10:13 AM | #2 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Need to understand the hole dual engine setup?
You need 2 motors...preferably matching. Depending on your radio...you'll need either 2 ESCs or a dig switch. You're gonna want a 10 amp BEC & decent servo with decent torque. Somewhere around the 300 oz marks a popular choice. 3s batteries are the norm but some go as low as 2s & others as high as 4s. Smaller packs are better. In the range of 450mAh-850mAh is the usual. You can get away with larger packs but its unnecessary weight. Sorry its so vague but there's a TON of helpful build threads here & Harley has a great sticky at the top of this section to help line you out. Do the searches & read Harleys guide. It's just too difficult to line someone out start to finish without em having a baseline of info. |
06-04-2012, 11:44 AM | #3 |
i understand and thanks for the reply it helps alot!
06-04-2012, 12:16 PM | #4 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
check out WARCRC when you get time as you are close to the area that we do are comps and get into the comp thing.....if you like that..new season starts in july..... |
06-04-2012, 02:11 PM | #5 | |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
| Re: Need to understand the hole dual engine setup? Quote:
06-04-2012, 03:25 PM | #6 |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
I was in your spot here is my first setup just to get going electronics wise 1 tekin fxr 1 rc4wd dig unit 1 jr sport ds8711 1 cc bec 2 tekin 45t motors And a 3 channel spectrum radio Nd 3 channel reciver. It got me up and going till I could afford another tekin and futaba 4pl, hope this helps! |
06-04-2012, 07:52 PM | #7 |
Pebble Pounder Join Date: Mar 2012 Location: Warren, Mi
You can go as complicated or as simple as you want. Good choice on the Savox servo. I run one and have had very good luck with it. Soon I will be getting another, stronger one. I would advise you to read through the various build threads in the XR10 section. Take a look and maybe ask some questions about how everyone else had done theirs. Harley has a sticky with quite a bit of useful information in that section as well.
Need to understand the hole dual engine setup? - Similar Threads | ||||
Wraith dual engine | supertato | Axial Wraith | 6 | 09-28-2011 08:49 AM |
Futaba 9CHP setup for dual steering, dual esc | duartev | Electronics | 5 | 06-07-2009 08:58 AM |
Dual 3s Lipo/Dual Sidwinders/Dual 4400KV Inrunners Setup Help Needed. | TheHeadHunter | Electronics | 16 | 08-17-2008 05:21 AM |
dual engine wk? | spiff2022 | HPI Wheely King | 14 | 02-22-2008 02:26 PM |
Dual servo setup?s | avsno2000 | Electronics | 3 | 09-12-2005 10:28 AM |
