Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: making links
Old 07-26-2006, 04:47 PM   #1
Default making links
Should I defeneatly use 4-40 threaded rod for these, or should I go bigger? Also, what size aluminum tubing would work as a good sleeve for the chosen threaded rod? If you know of a better link setup for a tlt just let me know.
somedude is offline   Reply With Quote
Old 07-26-2006, 05:13 PM   #2
PapaGriz Yo
Grizzly4x4's Avatar
Use the stock lowers from the TLT as your upper control arms or if you dont have the stockers use something like this.
http://www2.towerhobbies.com/cgi-bin...?&I=LXMHX0&P=7
For the lowers use these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXHFV7&P=7
or
http://www2.towerhobbies.com/cgi-bin...?&I=LXHFV9&P=7
or
http://www2.towerhobbies.com/cgi-bin...?&I=LXHFV8&P=7
If you want to build your own then use these rod ends:
http://www2.towerhobbies.com/cgi-bin...&I=LXJJ81&P=ML
and 6-32 threaded rod for a much stronger setup than the 4-40 stuff.
Grizzly4x4 is online now   Reply With Quote
Old 07-26-2006, 05:14 PM   #3
Well, it does say 4-40 right there.
Personally I wouldn't use anything but a bigger revo rod end that takes an 8-32 though.
Cloak is offline   Reply With Quote
Old 07-26-2006, 08:08 PM   #4
You sure those pushrods will work with maxx shafts and a stock chassis(for a little while)? If I do make my own links tho, what size tubing do I need!?
Old 07-27-2006, 08:21 AM   #5
I just made a set of links using this method, and it works great. I used M3 screws and these rod ends. Works a treat
4link4eva is offline   Reply With Quote
Old 07-27-2006, 09:01 AM   #6
That's the method I used last time, but friends are telling me I should go with the other method. I dunno, maybe I'll do the same way, they seem to be really tough.
Old 07-27-2006, 11:37 AM   #7
K_Willis's Avatar
I've found the easiest way to do it. Is to get 3/16 brakeline, cut it to size with a pipe cutter. Tap the hole for 6-32, and then put a dab of loctite on a 6-32 screw, screw it into the end, and then just cut the head off with my dremel. Works good, super easy, never broken a link, and only bent one once. I use the same rod ends Grizz recommended.
K_Willis is offline   Reply With Quote
Old 07-27-2006, 04:11 PM   #8
1*
rcr3fan29's Avatar
I suppose everyone has their preferred method. To me, the simplest method is 6/32 allthread, some 3/16 aluminum tubing, some Traxxas rodends and my dremel with a cutoff wheel.
rcr3fan29 is offline   Reply With Quote
